Roborock Valetudo RE zoned_cleanup using input_boolean buttons. (code help)
Hi, I am trying to get my xiaomi roborock vacuum running Valetudo RE to zone clean multiple zones using input_boolean buttons, using the below code. The code works when inserted into the template editor and also starts the vacuum when one zone is selected. But I am having trouble making it work with multiple zones. Any help would be great.
input_boolean:
  vac_lounge:
  vac_kitchen:
  vac_bedroom:
  vac_bathroom:
  vac_study:
group:
  vac:
    entities:
      - input_boolean.vac_lounge
      - input_boolean.vac_bedroom
      - input_boolean.vac_kitchen
      - input_boolean.vac_bathroom
      - input_boolean.vac_study
script:
  clean_xiaomi:
    alias: "xiaomi clean action"
    sequence:
      - service: vacuum.send_command
        data_template:
          entity_id: vacuum.rockrobo
          command: 'zoned_cleanup'
          params:
            'zone_ids': ["{{ expand('group.vac') | selectattr('state','equalto','on') | map(attribute='name') | list | join('\", \"') }}"]
Thanks.
You got most of the way there and thank you @K_Shot, because based on what you posted I was able to get it working.
So the issue appears to be that in a template, all template generated values are strings. If we look at the mqtt message that is published in response to your code instead of getting something like…
valetudo/rockrobo/custom_command {"command": "zoned_cleanup", "zone_ids": ["Kitchen"]}
…we instead get…
valetudo/rockrobo/custom_command {"command": "zoned_cleanup", "zone_ids": "['Kitchen']"}
…there is apparently no way to get a template to generate a list as opposed to a string.
However, there is a workaround. We can use a python_script to call the vacuum.custom_command service and have more control over the service data we send it. So to get this working we keep the same input_boolean and group configuration but also enable python_script and add a file called vac_clean.py to the config/python_scripts directory. We can then call python_script.vac_clean service which will use group.vac_rooms and vacuum.rockrobo but default but this can be changed.
configuration.yaml
python_script:
input_boolean:
  vac_living:
  vac_kitchen:
  vac_hall:
  vac_dining:
groups:
  vac_rooms:
    entities:
    - input_boolean.vac_hall
    - input_boolean.vac_living
    - input_boolean.vac_dining
python_scripts/vac_clean.py
group = data.get("group", "group.vac_rooms")
robot_id = data.get("entity_id", "vacuum.rockrobo")
logger.info( f"Check {group}, clean with {robot_id}" )
rooms = []
for entity_id in hass.states.get(group).attributes["entity_id"]:
	if hass.states.is_state(entity_id, "on"):
		rooms.append( hass.states.get(entity_id).attributes["friendly_name"] )
logger.info( f"Cleaning {rooms}" )
data = {"entity_id": robot_id,
		"params": {"zone_ids": rooms}}
hass.services.call("vacuum", "send_command", data )
