the current version of the roborock firmware has added the “cross-hatching” pattern when you set the (room or whole house) clean to (repeat) 2x or 3x.
the current integration does not allow for repeats on individual rooms (segments).
there is a method here:
“The original app for Xiaomi vacuum has a nice feature of room cleaning with repetition, you can achieve the same result with repeating segments:”
however, that does not enable the cross-hatch pattern.
I am able to perform a single room repeat that vacuums in a crosshatch but my questions is:
How to perform repeat crosshatch vacuuming in multiple rooms during a single cleaning session.
When I add the room ID twice in the params with multiple rooms [16, 16, 17, 17] only the last room is vacuumed twice in the crosshatch pattern. The first room (16) was vacuumed again after room 17 but in the first direction before returning the vacuum to the dock.
First search result on repeating segments not working brought me here.
Same issue, Roborock S7 MaxV, when I use “segments: [17, 17]” the vacuum will do a single run through the room. I prefer to use segments over zones because of odd room shapes, and I don’t want the vacuum to clean 1sqft of one room while doing the rest of another. If y’all have figured out how to make this work please speak up.
For the next person that comes across this, if you want to replicate the criss cross pattern from the Mi Home app x2 room cleaning use service: vacuum.send_command. This will give the expected behavior.
I imagine you already found the answer, but my experience has been that everything works. The map works exactly the same as the S4 that the MaxV replaced, all my automations go by rooms so I don’t know about zones (rooms are easier in comparison to grid coordinates).To clarify I have the S7 MaxV only, I bought the bot when it was released by itself and knowing I was going to get the fancy dock I didn’t get the auto empty dock.
There is a way to set the mopping and vacuum levels using the service call. However you have to dig really deep in to the Xiaomi documentation and I didn’t want to bother since my setup is working without issues for the last 3 months. I setup the vacuum/mop behavior in the Mi Home app and let it do its thing.
