I started seeing the same for one of my vacuums a while back, I don’t remember exactly when.
2023-11-07 19:47:08.005 INFO (MainThread) [homeassistant.components.xiaomi_miio] Fetching SOMENAME data recovered
2023-11-07 19:48:02.769 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Timeout fetching SOMENAME data
2023-11-07 19:48:23.002 INFO (MainThread) [homeassistant.components.xiaomi_miio] Fetching SOMENAME data recovered
2023-11-07 19:49:47.768 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Timeout fetching SOMENAME data
2023-11-07 19:50:03.001 INFO (MainThread) [homeassistant.components.xiaomi_miio] Fetching SOMENAME data recovered
2023-11-07 19:51:12.768 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Timeout fetching SOMENAME data
Running Wireshark seems to inficate that HA floods the vacuum with requests to port 54321 udp faster than the vacuum handles it. First it responds normally, then HA keep sending the requests and the vacuum simply doesn’t respond to those packets for a minute or so. Then it responds again. Then it doesn̈́t. And so on.
Seems to me like the vacuum has some kind of rate limiting for incoming requests, or it simply can’t keep up with them. I didn’t have time to investigate this further yet. Perhaps a workaround would be to edit some config/script and increase the interval.
I have several Roborocks vacuums of slightly different models and it only happens on the Q7 max.
