Robot Coffee Maker!
I attached a NodeMCU and a servo to my coffee maker so I can turn it on from bed. Or I could integrate it into my alarm system so the lights and coffee maker turn on at the same time when I need to wake up.
OK, so it’s not quite done yet and it’s really kind of a kludge, but I made a lot of progress last night.
I forked this code for MQTT-controlled blinds and adapted it for a servo connected to a Cuisinart Grind & Brew coffee maker. It’s weird because the coffee maker shows up as a light in HA, but I also kludged up my config so it at least appears to make sense. It has a little coffee cup icon and everything.
I have a couple issues in the tracker, if anyone wants to help out with that. Not quite sure what to do. I need the onboard LED to turn off, and I need the servo to not move when it powers up.
Also I need a proper case, and the servo is held on by a Command Strip and some electrical tape. That will only get me so far.
Here’s a video of the thing: https://ia601506.us.archive.org/2/items/RobotCoffeeMaker/Robot%20Coffee%20Maker.ogv
Lol worst video ever in the history of the internet. But on the other hand I like you code and I and going to steal it for my turny on thingy.
Thanks for the code much appreciated.
Yes, it is quite a bad video. I was very tired and without a tripod.
The video was good enough to get the idea. The parts have been ordered and next weekend is going to be my build date.
what is the section called coffee_brightness in the .ino file used for?
Also guessing that out pin 2 is the one controlling the servo. For my servo I got an mg995 servo which I had laying around.
That section is literally there to just make the program not break. Like I said, I adapted this from a blinds program. If you or someone else can make this make sense, you or they receive many thanks from me.
This bit helps with twit upon startup. You might need to change value in the Myservo.write(0) to get better results, mine was best with 0.
void setup() {
pinMode(2, OUTPUT);
myservo.write(0);
Config.yaml
  • platform: mqtt
    command_topic: “home/kitchen/coffee_payload”
    state_topic: “home/kitchen/coffee_state”
    payload_on: “ON”
    payload_off: “OFF”
    qos: 1
here is the newset updated code for 2 servos/switches doing on/off rather tht just simple button pressing, this is good for rocker type switches.
#include <Servo.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiAP.h>
#include <ESP8266WiFiGeneric.h>[
#include <ESP8266WiFiMulti.h>
#include <ESP8266WiFiScan.h>
#include <ESP8266WiFiSTA.h>
#include <ESP8266WiFiType.h>
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
#include <PubSubClient.h>
/************ WIFI and MQTT INFORMATION (CHANGE THESE FOR YOUR SETUP) ******************/
#define wifi_ssid "***" //enter your WIFI SSID
#define wifi_password "***" //enter your WIFI Password
#define mqtt_server "192.168.0.**" // Enter your MQTT server adderss or IP. I use my DuckDNS adddress (yourname.duckdns.org) in this field
#define mqtt_user "homeassistant" //enter your MQTT username
#define mqtt_password "********" //enter your password
WiFiClient espClient;
PubSubClient client(espClient);
Servo myservo;
Servo myservo2;
void setup() {
  pinMode(2, OUTPUT);
  myservo.write(25);
  myservo2.write(25);
  Serial.begin(115200);
  setup_wifi();
  client.setServer(mqtt_server, 1883); //CHANGE PORT HERE IF NEEDED
  client.setCallback(callback);
void setup_wifi() {
  delay(9);
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(wifi_ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(wifi_ssid, wifi_password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
    char p[length + 1];
    memcpy(p, payload, length);
    p[length] = NULL;
    String message(p);
    String mytopic(topic);
    if ( mytopic == "home/kitchen/coffee_payload" && message.equals("ON")){
      myservo.attach(D4);
      delay(500);
      myservo.write(78);
      client.publish("home/kitchen/coffee_state", "ON");
      delay(500);
      myservo.detach();
    else if (mytopic == "home/kitchen/coffee_payload" && message.equalsIgnoreCase("OFF")){
      myservo.attach(D4);
      delay(500);
      myservo.write(11);
      client.publish("home/kitchen/coffee_state", "OFF");
      delay(500);
      myservo.detach();
    else if ( mytopic == "home/kitchen/coffee2_payload" && message.equals("ON")){
      myservo2.attach(D6);
      delay(500);
      myservo2.write(78);
      client.publish("home/kitchen/coffee2_state", "ON");
      delay(500);
      myservo2.detach();
    else if (mytopic == "home/kitchen/coffee2_payload" && message.equalsIgnoreCase("OFF")){
      delay(500);
      myservo2.write(21);
      client.publish("home/kitchen/coffee2_state", "OFF");
      delay(500);
      myservo2.detach();
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
  if (client.connect("ESPBlindstl", mqtt_user, mqtt_password)) {
      Serial.println("connected");
      client.subscribe("home/kitchen/coffee_payload");
      client.subscribe("home/kitchen/coffee2_payload");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
