lars1
(lars)
December 3, 2018, 9:59pm
1
Hi
How would you alert the next rocket launch based on the new component Launch Library - Home Assistant ?
I’ve tried this in the template sand box:
Title:
next: {{ states(“sensor.next_launch”) }}
next: Falcon 9 Block 5 | SpX CRS-16
Date:
at: {{ state_attr(‘sensor.next_launch’, ‘launch_time’) }}
at: December 4, 2018 18:38:51 UTC
Convert to timestamp so we can alert 1 hr in advance:
alert at: {{ as_timestamp(state_attr(‘sensor.next_launch’, ‘launch_time’)) }}
alert at: None
No go. The best solution would be if the component could give us a timestamp, but can someone help me convert the date?
marco9446
(Marco Ravazzini)
December 3, 2018, 11:34pm
2
I think that i found a solution.
alert at: {{ as_timestamp(strptime(state_attr('sensor.next_launch', 'launch_time'), '%B %d, %Y %H:%M:%S %Z')) }}
nickrout
(Nick Rout)
December 4, 2018, 5:49am
3
Nice, and then we can start the stream on our TVs.
lars1
(lars)
December 4, 2018, 8:32pm
4
Thanks. This is what I ended up with:
alias: ‘Notify 1 hr before next rocket launch’
platform: time
minutes: ‘/60’
seconds: 00
condition:
condition: template
value_template: >-
{%- if (as_timestamp(now()) > (as_timestamp(strptime(states.sensor.next_launch.attributes.launch_time, ‘%B %d, %Y %H:%M:%S %Z’)) - 3600)) and ( as_timestamp( strptime(states.sensor.next_launch.attributes.launch_time, ‘%B %d, %Y %H:%M:%S %Z’) ) ) - ( as_timestamp( now() ) > 0 ) -%}
true
{%- endif -%}
service_template: notify.telegramchannel
data_template:
title: “Oppskytning om under en time”
message: “Oppskytning av {{ states.sensor.next_launch.attributes.agency }} kl {{ states.sensor.next_launch.attributes.launch_time }}. Se {{ states.sensor.next_launch.attributes.stream }}.”
Will tune it a bit. Timezone adjustments i.e.
marco9446
(Marco Ravazzini)
December 5, 2018, 3:07pm
5
It would be nice to have also a lovelace card with a countdown of the launch. maybe next week I’ll look into how to do it
Cee
(Si Gray)
December 6, 2018, 12:09am
6
Hey @lars1 I am using @jones custom component SpaceX sensors: Starman and next rocket launch for the SpaceX launches, but I can’t see the to get the notifications working for me from his script.
I have seen your setup, but I am not too good with templating. I have tried to modify it to matches the sensor and time format, but I can’t quite seem to get it right. Don’t suppose if you have a spare moment, you would might seeing where I might have gone wrong or something.
value_template: >-
{%- if (as_timestamp(now()) > (as_timestamp(strptime(states.sensor.spacex.state, ‘%M:%S’)) - 3600)) and ( as_timestamp( strptime(states.sensor.spacex.state, ‘%M:%S’) ) ) - ( as_timestamp( now() ) > 0 ) -%}
true
{%- endif -%}
It just use’s a time rather than date and year and month
although the main sensor uses this for it’s time.
Many thanks in advance if you can help out.
marco9446
(Marco Ravazzini)
December 6, 2018, 11:07pm
7
From what i can see, sensor.spacex
is a UNIX time. Since as_timestamp(now())
will give you another UNIX time, you can simply compare these two values.
Try to do something like this
{% if as_timestamp(now()) > states(‘sensor.spacex’) - 3600 %}
True
{% else %}
False
{% endif %}
Cee
(Si Gray)
December 7, 2018, 8:58am
8
Awesome, thank you very much @marco9446 Will have a play around
