Hi
I have this strange problem:
HA running under VMWare
If I restart the VM, all starts and working fine without errors. But if I do reset within the HA via WEB I get this error:
Logger: homeassistant.setup
Source: setup.py:210
First occurred: 1:31:25 PM (1 occurrences)
Last logged: 1:31:25 PM
Setup failed for xiaomi_miio: Unable to import component: cannot import name ‘ROCKROBO_S7_MAXV’ from ‘miio.integrations.vacuum.roborock.vacuum’ (/usr/local/lib/python3.10/site-packages/miio/integrations/vacuum/roborock/vacuum.py)
There is no option to restart again via WEB as it says
“The system cannot restart because the configuration is not valid: Platform error remote.xiaomi_miio - cannot import name ‘ROCKROBO_S7_MAXV’ from ‘miio.integrations.vacuum.roborock.vacuum’ (/usr/local/lib/python3.10/site-packages/miio/integrations/vacuum/roborock/vacuum.py) Platform error vacuum.xiaomi_viomi - cannot import name ‘ROCKROBO_S7_MAXV’ from ‘miio.integrations.vacuum.roborock.vacuum’ (/usr/local/lib/python3.10/site-packages/miio/integrations/vacuum/roborock/vacuum.py)”
They only option is to restart via the VMWare.
I’ve tried to access the file via hassio (vmware) , not luck there…
Ideas ?
