After a period of research I finally decided to start using Home Assistant. The installation process, using Docker Desktop, was flawless and I was up and running in 15 minutes. The autodiscovery however did not find anything. My SONOS, Hue Lighting, NEST thermostat all we not found. I tried adding the integrations through the interface once logged in, but still no luck with SONOS and NEST. I finally got the Philips Hue to work, but the rest does not link to HA.
Edit: NEST seems to be a paid service, it requires $5 to link it and SONOS still no luck.
I am running HA Docker on a Mac.
Discovery on Hue worked fine from the Integrations tab, not so much with SONOS.
Also I cannot add additional repositories. It seems like that has something to do with de Docker solution. I am seriously considering a dedicated Raspberry Pi for this.
I recall autodiscovery didn´t work for me either with Sonos and added it manually in yaml prior to it moving to the frontend. Did you follow hte instructions? Sonos - Home Assistant (home-assistant.io)
