Hello. When adding TP-Link Omada integration, I’m presented with 6 devices, 3 TP-Link access points, 1 TP-Link router and 2 Roku devices.
I have a fairly new HAOS installation on a RPi5 8gb, no custom configs or additions to the config file.
Why do the Roku devices show up like that? Is that normal? Did I press something?
tom_l
July 11, 2024, 11:55pm
2
Some devices can be discovered by multiple integrations. Which integration is the “primary” integration and is used for the brand logo is currently not defined, leading to this effect you are seeing. Fortunately it is only cosmetic and will not affect your device use in any way. There is an issue open for it:
opened 06:26AM - 08 Dec 22 UTC
### Checklist
- [X] I have updated to the latest available Home Assistant versi… on.
- [X] I have cleared the cache of my browser.
- [X] I have tried a different browser to see if it is related to my browser.
### Describe the issue you are experiencing
I have some Shelly 1PM (and other models) devices I setup with the same exact steps. Those devices are provided to HA from two integrations Shelly and Unifi Network. The thing is that they are not represented the same in HA especially in regards to Brand Logo!
Attached some screenshots.
### Describe the behavior you expected
Device brand icons to be represented according to their manufacturer.
### Steps to reproduce the issue
1. No specific steps!!
![01 Multiple Integration Entities](https://user-images.githubusercontent.com/63133627/206373788-6083270f-61d7-4e7d-b33c-9c86867d363c.jpg)
![02 Device ONE](https://user-images.githubusercontent.com/63133627/206373791-c6bb7d34-ab80-45f8-be0e-f9a8b83776fa.jpg)
![03 Device TWO](https://user-images.githubusercontent.com/63133627/206373792-c804cbb8-f5ed-434c-9188-915e272dab95.jpg)
### What version of Home Assistant Core has the issue?
Home Assistant 2022.11.0
### What was the last working version of Home Assistant Core?
_No response_
### In which browser are you experiencing the issue with?
Version 108.0.5359.95 (Official Build) (64-bit)
### Which operating system are you using to run this browser?
HA is installed on Intel NUC
### State of relevant entities
_No response_
### Problem-relevant frontend configuration
_No response_
### Javascript errors shown in your browser console/inspector
_No response_
### Additional information
_No response_
