My Roku Premiere is connected via ethernet and is pingable from my Home Assistant terminal. However, when I enter the IP address to add the integration back, it says “Failed to connect”. What am I missing? What changed to cause the Roku integration to no longer able to see the media player? This integration has worked for me for years until just recently. There isn’t much to configure other than entering the IP address of the Roku. Can someone please tell me what I’m missing? I really need this integration back since I depended on it.
There was a change to the Roku app in December? I think. Search here and you will find it. Something to change in your Roku software setup to allow external access.
Advanced System Settings/Control by Mobile Apps/Network access
Set it to: Permissive
Mine was set to ‘Limited’, but that was not working. ‘Permissive’ allows devices on the local network to send commands. Should be used with care on private networks only.
