Roku remote calls work but create log errors
My setup is a hassio install in a vm, on a vlan. I have roku’s on another vlan so discovery does not work. Rules are set up to allow the hassio install talk to any other network. The roku’s are defined in configuration.yaml and service calls will work, turning them off/on, changing sources, etc. But there is an exception in the logs whenever I call a service to them. It causes scripts to stop execution before completing. I can use curl and make command line ecp calls directly from the hassio command line with no errors. What is causing this error?
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 133, in handle_call_service
    connection.context(msg),
  File "/usr/src/homeassistant/homeassistant/core.py", line 1233, in async_call
    await asyncio.shield(self._execute_service(handler, service_call))
  File "/usr/src/homeassistant/homeassistant/core.py", line 1258, in _execute_service
    await handler.func(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
    self._platforms.values(), func, call, service_name, required_features
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 348, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 370, in _handle_service_platform_call
    await getattr(entity, func)(**data)
  File "/usr/src/homeassistant/homeassistant/components/roku/remote.py", line 62, in send_command
    getattr(self.roku, single_command)()
  File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 183, in command
    self._post(path)
  File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 212, in _post
    return self._call('POST', path, *args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 229, in _call
    raise RokuException(resp.content)
roku.core.RokuException: b''
