I have a Govee lightstrip behind my Onn television. I can use the tv on trigger to turn the light strip on but, even though it shows the tv off trigger as firing, it never calls the automation. I can get it to work by using the tv on or off trigger and toggling the lights which is not an ideal solution.
I can see that when I turn the TV off, the on or off trigger actually fires when the tv goes into standby. Is there a way that I can capture the standby event if I can’t get off to work?
Wanted to post an update here. Event though it is showing ‘tv turned off’ in the history, I don’t think it was actually/fully turning off due to the fast start option being enabled.
I was able to capture the standby state by looking at the state of the media player and explicitly turning the lights off that way.
