Roller blind as cover with controllable slider
Today I am trying to build an esphome controllable cover with slider. I have found workable code on here:
Below is my code which kinda works. I get:
All works, I can up and down it, and the slider follows…
But if I “set” the slider nothing happens. I think this is behavior as expected but I can’t find how to make that work.
Found this:
But I think I am overthinking this and I need a push in the right direction…
#https://community.home-assistant.io/t/motor-on-a-roller-blind-esphome-version/116179/109
substitutions:
  esp_name: esp32-07
  ssid: IOTDOM
  password: !secret IOTDOM_wifi_key
esphome:
  platform: ESP32
  board: wemos_d1_mini32
  on_boot:
    priority: -100
    then:
      - stepper.report_position:
          position: !lambda "return id(current_position);"
      - stepper.set_target:
          target: !lambda "return id(current_position);"
      - stepper.set_speed:
          speed: 500 steps/s
      - cover.template.publish:
          current_operation: IDLE
          position: !lambda 'return (float(float(id(blind_stepper).current_position) / float(id(open_position))));'
globals:
  - id: open_position
    type: int
    initial_value: '10000'
  - id: middle_position
    type: int
    initial_value: '3760'
  - id: current_position
    type: int
    restore_value: true
wifi:
  ssid: $ssid
  password: $password
  use_address: 192.168.6.68
  ap:
    ssid: "${esp_name} FBHS"
    password: !secret Fallback_Hotspot
captive_portal:
esp32_touch:
  setup_mode: False
# Enable logging
logger:
# Enable Home Assistant API
api:
  services:
    - service: control_stepper
      variables:
        target: int
      then:
            target: !lambda 'return target;'
        - globals.set:
            value: !lambda 'return target;'
    - service: set_speed
      variables:
        speed: int
      then:
            speed: !lambda 'return speed;'
    - service: middle
      then:
            speed: !lambda |-
              if (id(middle_position) >= id(blind_stepper).current_position) {
                return 500;
              } else {
                return 800;
            target: !lambda 'return id(middle_position);'
        - while:
            condition:
              lambda: |-
                return id(blind_stepper).current_position != id(middle_position);
            then:
                  current_operation: !lambda |-
                      if(id(middle_position) >= id(blind_stepper).current_position) {
                        return COVER_OPERATION_OPENING;
                      } else {
                        return COVER_OPERATION_CLOSING;
              - delay: 1000 ms
        - globals.set:
            value: !lambda 'return id(middle_position);'
ota:
stepper: #https://community.home-assistant.io/t/motor-on-a-roller-blind-esphome-version/116179/11
  - platform: uln2003
    pin_a: GPIO17
    pin_b: GPIO18
    pin_c: GPIO19
    pin_d: GPIO23
    max_speed: 500 steps/s
    sleep_when_done: true
    acceleration: inf
    deceleration: inf
i2c:
cover:
    device_class: shade
    open_action:
          speed: 500 steps/s
          target: !lambda "return id(open_position);"
      - while:
          condition:
            lambda: |-
              return id(kitchen_blind).position != 1;
          then:
            - delay: 1000 ms
          position: !lambda 'return 1;'
      - globals.set:
          value: !lambda 'return id(open_position);'
    close_action:
          speed: 500 steps/s
          target: 0
      - while:
          condition:
            lambda: |-
              return id(kitchen_blind).position != 0;
          then:
            - delay: 1000 ms
          position: !lambda 'return 0;'
      - globals.set:
          value: !lambda 'return 0;'
    stop_action:
          target: !lambda return id(blind_stepper).current_position;
      - globals.set:
          value: !lambda 'return id(blind_stepper).current_position;'
    has_position: true
time:
  - platform: homeassistant
web_server:
  port: 80
  - platform: uptime
    update_interval: 60s
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? String(days) + "d " : "") +
                (hours ? String(hours) + "h " : "") +
                (minutes ? String(minutes) + "m " : "") +
                (String(seconds) + "s")
              ).c_str();
text_sensor:
    icon: mdi:clock-start
  - platform: version
  - platform: wifi_info
    ip_address:
      name: "${esp_name} IP Address"
    ssid:
      name: "${esp_name} Connected SSID"
    bssid:
      name: "${esp_name} Connected BSSID"
    mac_address:
      name: "${esp_name} Mac Wifi Address"
  - platform: version
switch:
  - platform: restart
    name: "${esp_name} - ESP Restart"
have a look at this if you have the time. it works with a slider, perhaps you can get ideas from there what you might be missing.
Looking briefly at your code it looks as if you’d only have to change the stepper driver from a4988 that I’m using to yours ULN 2003.
Hi, did you get the slider working?
No, not in this way. I moved to Z2M now all problems are gone.
Hi, I would also be interested in motorising my roller blinds.
I used your script on Esphome an Home Assistent and I can control the stepper 28BYJ (down and up), but I would need the slider to control the position of the curtains and control them, could you tell me what you used with Z2M so I can buy the components?
Thanks and bye
