fastender
(Fastender)
March 10, 2021, 2:11pm
1
Hi, in the cover logic is something wrong.
I use the roller blinds from Ikea via deconz integration.
if moving the blinds from 0 to 100 then Home Kit accessory display CLOSING
if moving the blinds from 100 to 0 then HomeKit accessory display OPENING,
but if go to 100 then HomeKit accessory display OPEN and if go to 0 display CLOSED and that is wrong.
How I can “invert” it?
Using a template cover (https://www.home-assistant.io/integrations/cover.template/ ) I think you can create your own cover that is opposite of the actual one. Not sure if there’s a better way though.
Twit
(Simon)
March 11, 2021, 12:07pm
3
Do you have more than one blind and are they all inverted?
I only ask as I have 4 of them and only one was inverted. I deleted the pairing and repaired it and it was then correct.
Simon
fastender
(Fastender)
March 11, 2021, 12:25pm
4
I had solved it that way before, but by resettting (unpair) it again I was able to solve the problem, thank you very much.
I ran into a inverted issue during some API automation some how. I found if you don’t delete the device first and just repair you can get in a state where HA doesn’t know the closed or open state. Delete the device and repair and everything works
