Hi, does anyone use this configuration for roller blinds?..I get errors in compiling before flashing the nodemcu hope someone can help
Does not appear to be anything to do with home assistant. Why not post an issue on the github project?
I am just using this code now for some mqtt blinds. Have you included the helper files that came with the download? Also I had to downgrade one of my libraries (the Arduino json library) to an earlier version as the 6.x betas didn’t work.
Hope that helps
Sorry for the late response, it help me a lot I got it working, it works for a while but randomly it stops working, the open, stop and close work, only the slider is causing problems
