316097
(P)
1
Hi, I have a roller shutter hooked up and also a door sensor.
The door opens inwards, what would be the best approach to not be able to close the shutter when the door is open?
I open and close but manual and via scenes and automations.
Thankful for any help!
I have done this with an extra switch in front of the shutter controller. Else there remains always a risc…
Door open: shutter op 20s then turn off.
Door closed: wait 20s then tutn on.
316097
(P)
3
I’m not quite sure how you mean with that.
Have you got some yaml that I can look at?
sender
4
Who says yaml?
I use currently 2 program methods:
- in my Vera zwave controller -
a. PLEG
b. scenes
- home assistant - node-red
For your question specifically I have just a door sensor and a switch before the roller shutter.
I use 2 scenes:
- if door sensor opened, then open roller shutter, wait 20 seconds then switch off that switch.
- if door senor closed, wait 20 seconds then turn on that switch.
I can tell you how I did it with a scene in vera but not with yaml.
Sorry if that was what you were after, I just told you how I did it.
316097
(P)
5
Ahh, okay, thanks, but I’m looking to do it in yaml
