Roller shutter control
Hello everyone,
I am currently in the process of automatically controlling my roller shutters with HA.
But now there are some challenges.
I would like to briefly explain to you what I am currently doing.
This is how I currently lower my roller shutters:
alias: Rolladen Küche runter
description: ""
  - platform: time_pattern
    minutes: /15
condition:
  - condition: state
    entity_id: input_boolean.rolladen_automatik
    state: "on"
  - condition: template
    value_template: >-
      {{ not state_attr('automation.rolladen_alle_hoch_wenn_sonne_hinter_haus',
      'last_triggered').day==now().day }}
    enabled: true
  - condition: numeric_state
    entity_id: sensor.sun_solar_azimuth
    above: 58
    entity_id: sensor.sun_solar_elevation
    above: 7
    entity_id: sensor.netatmo_haus_buro_og_aussen_og_temperature
    above: 10
  - condition: or
    conditions:
      - condition: state
        entity_id: sensor.ort_condition
        state: sunny
      - condition: state
        state: partlycloudy
      - condition: state
        state: cloudy
    enabled: true
    entity_id: cover.homematicip_rollladen_kuche
    attribute: current_position
    above: 20
  - service: cover.set_cover_position
      position: 18
      entity_id:
        - cover.homematicip_rollladen_kuche
mode: single
This works so far without any problems.
But now I have several automations that raise my shutters again.
If outside is cooler than inside:
Automatic roller shutter activated
Cooler outside than inside
If bad weather outside:
Weather is not sunny or partly cloudy or cloudy
Outside below 25°C
When the sun has sunk behind the house:
Sun altitude below 12 °
Outside below 25°C
When sun has set:
sun has set
I didn’t want to post all the codes for booting right away, otherwise it would have been so huge :grinning_face_with_smiling_eyes:
My problem is now. The shutters came down this morning as requested. When the outside was cooler than the inside, they have been raised. 15 minutes later my automation shut down :disappointed:. In terms of content, this is of course logical. Now I have added this condition to my shutdown automation:
{{ not state_attr('automation.rolladen_alle_hoch_wenn_aussen_kuhler', 'last_triggered').day==now().day }}
Of course, the shutters wouldn’t have come down again today.
But my problem now is. Let’s assume my roller shutters come down. It becomes cooler outside than inside and this causes the roller shutter to go up again. But now it would get extremely warm outside again. With the current automation, the roller shutter would no longer go down.
Now I would be interested to know how you implement this for yourself?
Why not create a helper that is the temperature difference between indoor and outdoor temperature. Then you could trigger based on the numeric state of that helper (I’d suggest using a neutral bandwidth and only trigger when it goes, say, below -2° and above 2°).
Then add some conditions to make sure the automations don’t trigger when you don’t want them to.
I had already tried the control between inside and outside, but it wasn’t so successful :disappointed:
I then removed this check again
