I found only Fibaro Roller Shutter with zWave and Ubisys J1 (Shutter control J1 – ubisys). Ubisys is the only one I found which is matching my criteria but it’s super expensive - 149 € for piece.
If anybody knows about some other module it’d be great
I have same requirements. I also found these NodOn SIN-4-RS-20_PRO control via MQTT | Zigbee2MQTT - €65 Insta 57008000 control via MQTT | Zigbee2MQTT - I didn’t find it in any e-shop
When ZigBee is not requirement, you can be also interested in Shelly Qubino Wave Shutter (€35) which is also Z-Wave.
I also found WiFi module with tilt by F&F Fox WiFi blinds controller €60 SHUTTER - 230 V Wi-Fi blinds controller 230 V.
But I didn’t find a way to integrate it into HA.
When I did my research most of people told me they have Shelly 2PM and tilt only to 100 % by HA script (by opening rollers by 1 %).
I’m really concerned they aren’t better options yet. I don’t want z wave network but when new ZigBee controller with tilt will not be released soon I will buy Shelly Qubino modules.
Thanks for the topic btw.
The insta / nexentro ones work fine. The only annoying part is that the runtime calibration has to be done through pushing the button on the module. I have the problem that my shutters get tangled “quite often” and I have to set new endpoints to fix that. Hence, the runtime calibration is off and I have to get the module out of the wall to fix that.
Hence, I thought the Aeotec ZGA004 would be a great option since it can start the calibration via the attached switch. But even though it is listed as compatible via Z2MQTT, it’s not. It does not report the lift % back correctly and tilt does not work at all. If somebody could help me fix that controller, they would be another option as well.
So I’am back to this topic. I ended with wifi Shelly 2PM gen3 which can tilt shutters out of the box.
But topic is about Zigbee and that’s whay I am here once again.
Shelly 2PM gen4 can tilt AND it has support of Zigbee. That’s the solution.
