Roof light automation
Hi all
I’m brand new to HA and have a yellow box on order. Exciting! I’m an experienced Java/JS programmer (30y+) but not confident on the hardware side.
My home has 3 large roof windows that I’d like to automate as follows:
  • auto close when rain is detected
  • open/close based on internal room temperature
My existing hardware is as follows:
  • Window controller that drives the window motors via two 240v inputs (open/close). Motors are 24v but that doesn’t matter
  • Tado room thermostats that currently control the UFH. I’m hoping these will provide the room temperature readings.
And so what I’m missing is:
  • Rain sensor
  • Relay/bridges/io modules to interface with the rain sensor and window controller.
Any advice much appreciated:
  • Z-wave, zigbee or thread
  • Externally powered rain sensor suggestion (not wanting battery powered). I’m tempted to use dumb one connected to an io module?
  • Compatible interface for the window controller
  • Will I be able to use Tado as the internal temp sensor?
Regards
Paul
It is possible. Its almost the exact same as i have mine set (2 windows).
I use Zigbee stuff.
I have the Moes curtain switches that go behind the wall switches, other brands available. These provide position,opening, open, closed and closing.
I have that battery zigbee rain sensor (but its solar charged) that gives wet/dry, rain internancy and luminosity. I also have a old legacy rain sensor, this it just set to close the window, which inturn closes the others by automation.
I have 2 helper toggles, 2 generic thermostats using the tado temp as its sensor and the helper toggles as heaters relays.
It took some time to set it all up, but its now working purfect
I wish there was a blueprint
