I’m seeing errors in the logs. They look like this:
[homeassistant.components.mqtt.discovery] Received message on illegal discovery topic ‘homeassistant/switch/room-assistant/xxx.xx.xxx.xx-bluetooth-classic-inquiries-switch/config’
It seems to be coming from the mqtt discovery.py because the topics end in config.
I can’t seem to figure out if this is a problem with my configuration or an issue with either room assistant or home assistant and I would appreciate any insights anyone may be able to offer.
