Hello together,
I’ve been browsing the forum for some time to find my perfect combination for a room climate card.
At the end of my search I have built from several fontend integrations a (hopefully also for you) quite decent card together.
In addition to the room climate with the temperature of the thermostat and a separatem temperature / humidity sensor, the individual battery statuses of the devices in the zone are also displayed with a right swipe.
The code is certainly not perfect and it would be even more possible, but so far I’m satisfied and it works.
What you need:
- vertical-stack-in-card (also works without, but looks better with)
- swipe-card
- simple-thermostat
- mini-graph-card
- and of course devices like a thermostat
simply add a manual card (bottom item) - and insert the code. then change the individual names and entities and you’re done.
code to apply:
cards:
- type: custom:vertical-stack-in-card
cards:
- type: custom:swipe-card
cards:
- entity: climate.homematicip_accesspoint_wohnzimmer_zone
name: Heizung Wohnzimmer
layout:
step: row
mode:
names: true
icons: true
headings: true
control:
hvac:
heat: true
auto: true
preset:
boost: true
Arbeitswoche: false
Sommer: false
type: custom:simple-thermostat
header:
name: Heizung Wohzimmer
- type: entities
entities:
- entity: binary_sensor.homematicip_accesspoint_fensterkontakt_battery_2
- entity: >-
binary_sensor.homematicip_accesspoint_thermostat_wohnzimmer_battery
- entity: sensor.tuya_sensor_1_battery
- entity: sensor.0xb43a31fffe54dd94_battery
name: Ikea Fernbedienung
title: Batterizustände
- align_state: center
type: custom:mini-graph-card
entities:
- color: green
entity: sensor.homematicip_accesspoint_thermostat_wohnzimmer_temperature
- color: red
entity: sensor.tuya_sensor_1_temperature
- color: '#3399FF'
entity: sensor.tuya_sensor_1_humidity
y_axis: secondary
show:
graph: line
legend: true
extrema: true
labels: true
hours_to_show: 48
points_per_hour: 4
animate: true
