Room Humidity Control for Climate (HVAC) Devices
Monitor indoor moisture dynamics and automate your climate device so it reacts like an intelligent environmental system rather than a dumb switch. When a humidity sensor exceeds a defined upper threshold, the climate device automatically enters dry HVAC mode to remove excess moisture; when humidity falls below a defined lower threshold, the device switches off to conserve energy and avoid unnecessary cycling. Designed for clarity and predictability, this automation reduces overshoot and keeps humidity within comfortable bounds without constant manual intervention.
Required Components:
  • Humidity Sensor
  • HVAC compatible climate device
Tested on:
  • Samsung WindFree Avant S2 :white_check_mark:
