So i’m currently working on room by room presence detection.
I want to turn lights on and off and scene based on when someone enters a room and have it turn off after a certain amount of time after.
My first thought was motion, but they were hit or miss and the cooldown time i didn’t like. Also if i was eating dinner, my lights would turn off because they didn’t detect motion for that set amount of time.
So then I started to look at BLE. I looked into room assistant, but i already have PIs running LMS and squeezeboxes in every room and didn’t want to add another PI to every room. So i found ESPresence and bought some ESP32’s and got it up and running. And it did suprisingly well at figuring out what room i was in. but it was slow…took maybe 1-2 minutes to update my location per room. Also i didn’t like the idea of always having to have a tracker on my person, maybe if it was close to instant that wouldn’t be an issue, but it is…so that idea…for now, is out.
So I came upon a thread on here that used PIR as well as energy monitoring to tell weather a room is occupied or not. Also i swapped up my “dumb” zigbee motion sensors used from the alarm world and got some Phillips hue occupancy sensors (thoes made a world of difference) and got a few TP Link KP115s.
The thought is to have a “Occupancy” boolean setup for every room that when there is no motion, but when the KP115s are drawing current (setup on most used appliances in each room) to turn on and show the room as occupied, and turn off when both the PIR is not sensing motion and there is no current draw from the KP115s.
This is the only way that i can see to get the quickness of PIR for timing lights, but with the accuracy of actually being able to tell if someone is in a room being still, or not…
is there anyone that has gone through this same struggle and have found a viable solution that has worked for them?
