Room Scene Selector - Use button presses, motion sensors, and optional hold actions for efficient automation
This blueprint allows you to automate scene selection and manage lights efficiently using button presses, motion sensors, and configurable action types. It replaced a few dozen automatons for my single button scene selection with a few bells and whistles. It’s highly opinionated but I still hope someone finds it useful.
Here are the updated features and inputs required to get started:
Features:
  1. Scene Selection: Use a button device to cycle through scenes.
  2. Light Management: Turn off lights in selected areas or specific lights on a configurable action (double press or hold).
  3. Automatic Turn Off: Configure a delay to turn off lights automatically.
  4. Occupancy Monitoring: Use a motion sensor to monitor room occupancy and turn off lights after a specified duration.
  5. Configurable Special Action: Execute an optional automation, script, or scene on a configurable action (double press or hold).
Inputs:
  • Turn Off Action: Configure the action type for turning off lights (double press or hold).
  • Special Action Type: Select the action type for executing a special action (hold or double press).
  • Scene Selection Helper: Input helper for scene IDs.
  • Button Devices: Button devices for triggering scene selection.
  • Target Areas for Light Control: Areas to turn off lights on the configured action.
  • Target Lights for Control: Specific lights to turn off on the configured action or automatically.
  • Automatic Turn Off Delay: Delay before lights turn off automatically.
  • Special Action: Optional automation, script, or scene to execute on a configured action.
  • Motion Sensor: Sensor to monitor occupancy.
  • Motion Sensor Duration: Time for the motion sensor to stay clear to turn off the lights.
Triggers:
  • Single Press: Cycle to the next scene and activate it.
  • Configurable Turn Off Action: Turn off lights in the target areas or specified lights.
  • Configurable Special Action: Execute the special action (automation, script, or scene) on the specified action type.
  • Occupancy: Turn off lights when no motion is detected for the specified duration.
Blog post & Gist: Home Assistant Blueprint: Room Scene Selector | Vladimir Cvetić | Vault of Vital Nonsense
UPDATES:
  • Implemented a feature to reset the input selector each time the lights are turned off, ensuring the scene selection starts from the first option in the list.
  • Applied this reset logic to both button-triggered light-off actions and automatic light-off via occupancy sensors, improving consistency in scene management.
How does this work? Sorry for maybe asking the obvious, but I currently use node-red to do all my light automations, but I want to switch to native HA. And this blueprint is exactly something I was looking for.
And is it possible to switch the button press? as i’m used to Hold to turn off and double press for special action. Would be great if I could swap them, so everyone does not need learn to use the light again.
Go to devices, helpers and then create helper. Select input helper as option. There you can create a list of strings (new input text fields). This is the docs: Input select - Home Assistant
Then just create a list of scene id’s and input them there.
Not currently, but it could be easily modified to allow for it. I’ll post updated version in next week or so.
Thanks for the explanation, ill look into it.
Also thanks for adding the option to switch button behavior.
Blueprint is now updated and you can select type of action to use (hold, double)
Hi, the blueprint is a great idea, however I can’t find my buttons. I’m using Z2M with some Zigbee aqara buttons, and they are exposed as devices, not entities.
Therefore from your blueprint I can select the device voltage/temperature, but not select the device to trigger a single action. How can I fix that?
My approach relies on “_action” entities provided by Zigbee2Mqtt. In latest releases that approach has been deprecated by Z2M team, you’ll need to enable legacy integrations.
Reference: ACTION entity on my buttons are no longer exposed to HA · Issue #25544 · Koenkk/zigbee2mqtt · GitHub
I’m using this blueprint in my entire setup pretty extensively, I still haven’t gotten around it but blueprint will be updated to support MQTT device trigger sooner rather then later.
