Hi! I am building a new home and I am about to order installation of floor heating (water based, connected to NIBE heat pump). Each room will have its own loop with electric valves connected to Shelly DIN relays (so opening/closing will be controlled by HA). Each room will need a wall thermostat, temp sensor, floor temp sensor and floor dew sensor (for reverse-loop mode for cooling in summer). I don’t want “dumb” (and ugly) thermostat knobs so the idea is like this:
- Some sort of 4" touch screen - Like Shelly Wall Display or Sonoff NS Panel Pro (side-loaded FullKiosk mode for HA) // This provides the Thermostat control (+ some extra dashboard functions)
- Shelly 1 Gen3 + Shelly Plus Add-On + DS18B20 // This provides the Floor temperature sensor (to be used to avoid overheating the floor)
I don’t have a real use for the Shelly relay (no light connected to it) but unless I am wrong the AddOn can’t run on its own (no wifi) and can not be connected to the touch panels. On the other hand it will give me some future opportunity to use if i ever need one. Two questions:
- Is the above solution OK? Yes, the relay is unused but I haven’t found prebuilt solution for DS18B20 which would fit behind the panel inside installation box. I am a bit under time pressure so i can’t DYI something so I prefer “plug and play” solution (connect the cables, connect to wifi/ZHA and done…)
- What floor dew point sensor should i use and “how”? I need that to avoid cold water in the loop going “too cold” (in reverse/cooling mode) as it would cause dew/moisture. Also it would be excellent if i could use it with the Shelly AddOn (even though the support page does not say anything about such device support)
Thank you in advance for any help/suggestions !
