First time I start a post here so please bare with me.
I installed the iRobot integration yesterday. I followed the integration guide from the docs. Added the component through the hass integrations webpage and then added the following code to my configuration.yaml:
roomba:
- host: XXX
blid: XXXX
password: XXXX
continuous: false
delay: 5
Everything was working fine (roomba was integrated, I could see its status and I think I even got it moving from my HASS frontend).
Today I was working on its custom card for my frontend and at some point I restarted HASS and (I think after that) Roomba was reported as unavailable. I tried to edit the integration through the online interface, but there is no editing there.
I deleted the roomba entry and restarted HASS and still nothing.
I tried to delete the integration trough the interface but it wouldn’t go away (after deleting the integration was still there).
Long story short (many restarts of HASS and other stupid things) I decided to delete all the entities of the integration.
And other unwise actions that I may not remember.
Long story short here is the situation now:
- Without the roomba entry in my config.yaml: I get this error in the log:
2020-06-29 22:30:05 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140591752978832] Error handling message: Unknown error
File "/home/homeassistant/srv/homeassistant/lib/python3.8/site-packages/homeassistant/components/websocket_api/connection.py", line 95, in async_handle
handler(self.hass, self, schema(msg))
File "/home/homeassistant/.homeassistant/custom_components/browser_mod/connection.py", line 36, in handle_update
devices[deviceID].update(msg.get("data", None))
File "/home/homeassistant/.homeassistant/custom_components/browser_mod/connection.py", line 72, in update
self.sensor = self.sensor or create_entity(
File "/home/homeassistant/.homeassistant/custom_components/browser_mod/helpers.py", line 30, in create_entity
adder = hass.data[DOMAIN][DATA_ADDERS][platform]
KeyError: 'sensor'
- With the roomba entry in the config yaml: I get an error in the log:
2020-06-29 22:15:05 ERROR (MainThread) [homeassistant.setup] Setup failed for roomba: Unable to import component: cannot import name 'Roomba' from 'roomba' (unknown location)
Note that I do not get the browser_mod error (error #1 above) when the roomba integration is in my config.yaml (and to the best of my knowledge there is no frontend for roomba in my system yet - so I do not understand how having the roomba integration - which is not working - helps with the browser_mod error???).
In both cases the iRobot integration has disappeared from my Integrations interface but trying to add it does nothing. (integration window exits).
Other relevant (or irrelevant) info:
- Running HASS on Linux server (ClearOS which is like CENTOS)
- Roomba is 980 and working fine (iOS app working fine also)
- Got BLID and PW through dorita.
Any ideas?
