Roomba j5+/j7+/j9+ integration
hi! i have a j9+, but process should the the same for the j5+ and j7+ since all three have mapping and mop.
Im trying to setup a python script for homeassistant that gives the option to vacuum or mop separately on specific rooms. There’s a script around that works perfectly for the rooms selection, but lacks the mop switch to enable or disable.
There’s one around (Python script for roomba j9+), but doesn’t work(at least for me)), i believe because of the message params being sent. The roomba just mops and cleans everything with that script.
How and or where can i know the message params that needs to be sent? Reverse engineering the roomba apk? Im totally lost.
Thank you!
Hello, how did you manage to connect the robot to the home assistant? It always gives a password error…
In my case its probably the params being sent, i dont know where or how to obtain them. Im still fighting the same error, no luck.
Hello, I really would like to know how you got it working with the local script in your link. I got the BLID and password. I only have the vacuum version and not the mop so integration of it in HA with cleaning everywhere is better then no integration at all? How dit you make it work (script in config/python_scripts/roomba-j9-script.py) but then what? thanks in advance.
I have the J5 model but I can’t retrieve the password.
I retrieve the models details, but then at the end it shows “Error getting password. Follow the instructions and try again.”
Hi! How are things with j9+ in 2025? Is there a proper working integration?
