I just got a roomba and have been following the instructions from the roomba component to get the password but it keeps failing. Has anyone been able to get this information? I get this when trying doritos script
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node',
1 verbose cli '/usr/local/bin/npm',
1 verbose cli 'run',
1 verbose cli 'getpassword',
1 verbose cli '192.168.86.118' ]
2 info using [email protected]
3 info using [email protected]
4 verbose run-script [ 'pregetpassword', 'getpassword', 'postgetpassword' ]
5 info pregetpassword [email protected]
6 info getpassword [email protected]
7 verbose unsafe-perm in lifecycle true
8 info [email protected] Failed to exec getpassword script
9 verbose stack Error: [email protected] getpassword: `node ./bin/getpassword.js "192.168.86.118"`
9 verbose stack Exit status 1
9 verbose stack at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:214:16)
9 verbose stack at emitTwo (events.js:87:13)
9 verbose stack at EventEmitter.emit (events.js:172:7)
9 verbose stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
9 verbose stack at ChildProcess.emit (events.js:172:7)
9 verbose stack at maybeClose (internal/child_process.js:821:16)
9 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
10 verbose pkgid [email protected]
11 verbose cwd /home/pi/roomba_pw/dorita980
12 error Linux 4.9.41-v7+
13 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "getpassword" "192.168.86.118"
14 error node v4.3.2
15 error npm v2.14.12
16 error code ELIFECYCLE
17 error [email protected] getpassword: `node ./bin/getpassword.js "192.168.86.118"`
17 error Exit status 1
18 error Failed at the [email protected] getpassword script 'node ./bin/getpassword.js "192.168.86.118"'.
18 error This is most likely a problem with the dorita980 package,
18 error not with npm itself.
18 error Tell the author that this fails on your system:
18 error node ./bin/getpassword.js "192.168.86.118"
18 error You can get their info via:
18 error npm owner ls dorita980
18 error There is likely additional logging output above.
19 verbose exit [ 1, true ]
