Roon is an amazing HD audio multiform service (I am just using it and have absolutely no affiliation with the company) and it seems that a API for Javascript is available (https://github.com/RoonLabs/node-roon-api)
Is anyone working on an integration or interested to work on this project?
I’m interested to so that ROON would be voice controlled via HA. Both are installed on a Synology DS918+, music (from flac tot DSD and even some MQA) resides also on the NAS. I have two Intel NUC’s for ROCK but direct on the NAS works perfectly so the NUC’s are now ESXi servers. Thus Marcel for President
Thanks for the integration @marcelveldt does the Roon integration need to be kept current, I’m starting to go down the HASS route and one of the things I would like to do is take advantage of the new “Auto Sleep” feature in Roon that I believe works through “Standby” functionality in “Transport”, I’m assuming you setup Roon with an extension that creates a “HASS switch” style device, music stops, Roon signals HASS through the API that the “HASS switch” should be turned off, in my case the actual switch would be the Wemo WiFi power switch that I currently use to remotely switch on/off my amplifier?
