Rooted Toon integration
Hi there,
I have a rooted toon integrated in HA.
Works like a charm, but…
It keeps on being discovered as a new integration after each restart…
I have a correct “Consumer Key” and “Consumer Secret” from https://api.toon.eu/ (as described here )
However, when I hit ‘configure’ it first opens https://api.toon.eu/ and immediately redirects me to a useless Eneco page where I cannot sign in, as I do not use any of the mentioned energy providers (as my toon is rooted)
So how do I prevent toon from being rediscovered ??
It look like you installeren the Toon add-in insted of the rooted-toon bey Hacs
Hi Siepie,
hmm, can’t find anything resembling rooted-toon in Hacs.
So yeah, i use Toon
(works fine, except it is re-discovered after each restart of HA)
Do you happen to have the repository name??
I see
Toon boiler Status
Toon Climate
And
Toon smart Meter
Go to Hacs (separate install)
Integrations
And than ad
Ah, Siepie, i think you misunderstood my question;
My (rooted-) toon is fully operational and I can control all functions as well as see all info from toon on my Home-assistant.
However, every time i restart HA. i get the notification a new device was discovered,
which eventually lead me to eneco.nl That on itself is not a problem, but it is just annoying…
@aceindy, You need to open configuration.yaml. Remove the following lines there and restart your Home Assistant and your problem will be solved.
toon:
  client_id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  client_secret: xxxxxxxxxxx
Hello Rtrinks,
Thanks… but those lines have been commented out a looong time ago already…
So that’s not it…
Maybe it was something in core, but i haven’t seen the message for some time now…
Hopefully the ‘dismiss’ has become a permanent one :crossed_fingers:
