Rotary dimmer as volume control SOLVED
Not sure if the quetsion is pointed at me. I am not using Deconz but zigbee2mqtt so sorry, cannot help you with Deconz
I found the solution here:
So now itā€™s all very nice! And more rotary dimmers/volume controls are on their way.
In case itā€™s useful to anyone, I adapted Xydixā€™s nifty code to work with Zigbee2mqtt rather than deCONZ.
Hereā€™s the automation part - no change to the scripts. I added an extra boolean flag (ā€˜updownā€™) to indicate whether the volume was increasing or decreasing because the ā€˜rotate_stopā€™ payload will be triggered in both cases. Hacky and doubtless not the proper way to do it (my programming skills are minimal), but it works. Thanks again Xydix for the original code. Replace ā€˜zigbee2mqtt/Symfonisk IKEA volumeā€™ with whatever the name of your Symfonisk remote is in MQTT.
  - alias: symfonisk raise volume on
    initial_state: 'on'
    - platform: mqtt
      topic: 'zigbee2mqtt/Symfonisk IKEA volume'
    condition:
    - condition: template
      value_template: "{{ 'rotate_right' in trigger.payload }}"
      - service: input_boolean.turn_off
        entity_id: input_boolean.symfonisk_volume
      - service: script.turn_on
        entity_id: script.symfonisk_raise_volume
        entity_id: input_boolean.symfonisk_updown
  - alias: symfonisk raise volume off
    initial_state: 'on'
    - platform: mqtt
    condition:
      value_template: "{{ 'rotate_stop' in trigger.payload }}"
    - condition: state
      state: 'off'
  - alias: symfonisk lower volume on
    initial_state: 'on'
    - platform: mqtt
    condition:
      value_template: "{{ 'rotate_left' in trigger.payload }}"
        entity_id: script.symfonisk_lower_volume
  - alias: symfonisk lower volume off
    initial_state: 'on'
    - platform: mqtt
    condition:
    - condition: state
      state: 'on'
Hello robban,
Would it be possible, that you share a short Tutorial of your solution.
I would like to have the Same setup as you.
Thanks in advance.
Best regards,
Dominik
Here is my AppDaemon application https://github.com/Kane610/appdaemon-apps/blob/a08097a717c4b219850978931f9231b1fb4edd7b/symfonisk_controller.py
Thank you for your quick reply, i will test it, when my controller arrive!
hi @Robban how are you?
how can I use this AppDaemon script?
any guide/help?
Thanks!
Set up appdaemon copy the app into the app folder configure an app i Arion wit on these parameters
[remote_id] -- [remote id]
[media_player_entity_id] -- [media player entity id]
Ummm typo?
hi @Pabs how are you?
I use your code, but with a single touch in volume button, the volume goes all up or all down.
Any advice?
Thanks!
Hi @pitoganzado - the code I posted was just the automation part, so did you define the necessary extra boolean in your configuration.yaml?
Something like (please excuse the formatting, donā€™t forget the necessary indentations):
input_boolean:
symfonisk_updown:
name: Symfonisk up or down
initial: off
@Pabs thanks, missing exactly that! Now works amazing!
I add Play/Pause, skip forward and skip backward to the code.
Maybe this can help someone, this is my entire package ( symfonisk.yaml ).
Just change the ā€œmedia_player.cozinha_2ā€ and the topic ā€˜zigbee2mqtt/Sonos Controladorā€™ to yours devices.
input_boolean:
  symfonisk_volume:
    initial: off
  symfonisk_dummy_delay:
  symfonisk_updown:
    initial: off
script:
  symfonisk_lower_volume:
    sequence:
      - condition: state
        state: 'on'
        entity_id: input_boolean.symfonisk_dummy_delay
      - service: media_player.volume_set
        entity_id: media_player.cozinha_2
        data_template:
          volume_level: '{{ states.media_player.cozinha_2.attributes.volume_level - 0.01 }}'
      - service: script.turn_off
  symfonisk_raise_volume:
    sequence:
      - condition: state
        state: 'off'
        data_template:
          volume_level: '{{ states.media_player.cozinha_2.attributes.volume_level + 0.01 }}'
automation:
  - alias: symfonisk skip forward
    initial_state: 'on'
    - platform: mqtt
      topic: 'zigbee2mqtt/Sonos Controlador'
    condition:
      value_template: "{{ 'skip_forward' in trigger.payload }}"
      - service: media_player.media_next_track
  - alias: symfonisk skip backward
    initial_state: 'on'
    - platform: mqtt
    condition:
      value_template: "{{ 'skip_backward' in trigger.payload }}"
      - service: media_player.media_previous_track
  - alias: symfonisk play/pause
    initial_state: 'on'
    - platform: mqtt
    condition:
      value_template: "{{ 'play_pause' in trigger.payload }}"
      - service: media_player.media_play_pause
    initial_state: 'on'
    - platform: mqtt
    condition:
    initial_state: 'on'
    - platform: mqtt
    condition:
    - condition: state
      state: 'off'
    initial_state: 'on'
    - platform: mqtt
    condition:
    initial_state: 'on'
    - platform: mqtt
    condition:
    - condition: state
      state: 'on'
Thank you for your appdaemon code. Works like a charm!
How to configure apps.yaml and remote and symfonsik ID?
I get the following failure
2020-01-28 06:24:44.930091 INFO AppDaemon: Terminating Symfonisk_Controller
2020-01-28 06:24:44.937578 INFO AppDaemon: Reloading Module: /config/appdaemon/apps/symfonisk_controller.py
2020-01-28 06:24:44.951831 INFO AppDaemon: Initializing app Symfonisk_Controller using class SymfoniskController from module symfonisk_controller
2020-01-28 06:24:44.960769 INFO Symfonisk_Controller: {'module': 'symfonisk_controller', 'class': 'SymfoniskController'}
2020-01-28 06:24:44.965225 WARNING Symfonisk_Controller: ------------------------------------------------------------
2020-01-28 06:24:44.967035 WARNING Symfonisk_Controller: Unexpected error running initialize() for Symfonisk_Controller
2020-01-28 06:24:44.968514 WARNING Symfonisk_Controller: ------------------------------------------------------------
2020-01-28 06:24:44.971692 WARNING Symfonisk_Controller: Traceback (most recent call last):
  File "/usr/lib/python3.8/site-packages/appdaemon/app_management.py", line 145, in initialize_app
    await utils.run_in_executor(self, init)
  File "/usr/lib/python3.8/site-packages/appdaemon/utils.py", line 276, in run_in_executor
    response = future.result()
  File "/usr/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/config/appdaemon/apps/symfonisk_controller.py", line 26, in initialize
    self.remote = self.args["symfonisk_sound_controller_1"]
KeyError: 'symfonisk_sound_controller_1'
2020-01-28 06:24:44.973586 WARNING Symfonisk_Controller: ------------------------------------------------------------
Hope you can support me, thanks in advance
Just followed your example and made the necessary changes. I am able to successfully use the symfonisk volume controller to skip fwd (double tap), skip back (triple tap) and play/pause (single tap).
However, turning clockwise or counter clockwise does not affect volume. I donā€™t see any errors in the logs, the automatons and scripts are called accordingly when i turn or click the remote.
I am new to SYMFONISK, and thinking about getting it. Which route do you guys suggest going Zigbee2mqtt or Deconz route? Which is easier to set up and works smoother?
Can you share your devices.yaml configuration for the remote? Iā€™m using 0.01 but still having problems.
ok, got it resolvedā€¦ had a mistake in the script section.
Works fine now. Thanks for the help
Iā€™ve just copied&pasted this into my configuration and did the search&replace as noted in the comment from @pitoganzado. Volume control works perfectly for me! Thank you very much! :slight_smile:
got the symfonisk volume working ok, using conbee/zha/node-red, but when I tap the button once, I get three zha events in rapid succession (sub second). Iā€™m stumped, does anyone have any suggestions how I investigate further?
Thanks.
