Hi folks, I am hoping if someone could help me with the esphome code to mimic rotary encoder in ESPhome. I can successfully read the orientation rotary encoder turned in esphome via the following code.
- platform: rotary_encoder
pin_a: D5
pin_b: D7
on_clockwise:
- logger.log: "Turned Clockwise"
- homeassistant.service:
service: input_number.set_value
data_template:
entity_id: input_number.volume
value: !lambda "return id(volumeselect).state + 0.1;"
on_anticlockwise:
- logger.log: "Turned Anticlockwise"
data_template:
value: !lambda "return id(volumeselect).state - 0.1;"
# HEATING TARGET TEMP FROM HASSIO
- platform: homeassistant
internal: true
on_value:
- sensor.rotary_encoder.set_value:
value:
I am able to increase/decrease volume I turn the knob in either direction but getting incorrect value.
- My amplifier shows 45 as max volume. I like this to align this with 100% in HA. Right now it only shows volume increased or decrease. how to update correct value in HA.
- I like to mimic rotarty encoder. When I increase or decrease volume in HA, I like to adjust volume accordingly. I created helper
input_number.volumefor this purpose. How can I achieve this? I have encoder pin a connected to GPIO14 and pin b is connected to GPIO4. how to adjust code to mimic rotary encoder when I increase or decrease volume in HA?
Appreciate if someone can advise and help me on the code side?
Thank you.
