Rotary Encoder to control cover position
Hi all,
I am trying to use a rotary encoder to control a cover position. I am able to achieve this using several automation’s but I’m sure there must be a shorter way to do using lambas which I have no experience with.
Looking around this forum I have came up with the below code which does not work.
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "xxxxxxx"
  password: "xxxxxxx"
  ap:
    ssid: "Rotary Test Fallback Hotspot"
    password: "xxxxxxxx"
captive_portal:
logger:
api:
  password: "xxxxxxxxx"
ota:
  - platform: rotary_encoder
    pin_a: 0
    pin_b: 2
    filters:
     - or:
        - debounce: 0.1s
        - delta: 3
    resolution: 1
    min_value: 0
    max_value: 10
    on_value:
      then:
        - homeassistant.service:
            service: cover.set_cover_position
            data_template:
              entity_id: cover.front_blinds
              position: "{{ position_1 | int }}"
            variables:
              position_1: 'return id(Rotary Encoder).state * 4;'
I’m sure there is something I am missing that someone could help me with.
Thanks in advance
I’m doing exactly the same thing but using an encoder with PWM output. At the moment I solved it like this:
switch:
  - platform: gpio
    pin: GPIO12
    name: "Cover Open Switch"
  - platform: gpio
    pin: GPIO13
    name: "Cover Close Switch"
  - platform: duty_cycle
    pin: GPIO15
    name: Duty Cycle Sensor
    update_interval: 2s
    unit_of_measurement: "%"
    accuracy_decimals: 0
    filters:
      - calibrate_linear:
        - 2.9 -> 0.0
        - 97.1 -> 100.0
      - or:
        - throttle: 600s
        - delta: 5
    on_value:
      - cover.template.publish:
          position: !lambda "return x/100;"
cover:
    open_action:
      # Cancel any previous action
      - switch.turn_off: close_switch
      # Turn the OPEN switch on briefly
      - switch.turn_on: open_switch
      - delay: 5s
      - switch.turn_off: open_switch
    close_action:
      - switch.turn_on: close_switch
      - delay: 5s
    stop_action:
    optimistic: false
    assumed_state: false
    has_position: true
However I have not figured out yet how to give a position setpoint (or how to control to a position which is not 0% or 100% that is)
Ok, I’m having a rethink. I am trying to complete the whole project in esphome but I am struggling
still with the rotary encoder.
I what to call a certain action when the encoder value increases and a different action when the value decreases.
the code I have which does work is as follows.
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: ""
  password: ""
  ap:
    ssid: "Passage Blind Fallback Hotspot"
    password: ""
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: ""
  services:
    - service: control_stepper
      variables:
        target: int
      then:
        - stepper.set_target:
            target: !lambda 'return target;'
ota:
  password: ""
web_server:
  port: 80
# physical connection
stepper: #https://community.home-assistant.io/t/motor-on-a-roller-blind-esphome-version/116179/11
  - platform: uln2003
    pin_a: D0
    pin_b: D5
    pin_c: D6
    pin_d: D7
    max_speed: 250 steps/s
    sleep_when_done: true
    acceleration: inf
    deceleration: inf
# items for Home Assistant
cover:
    device_class: shutter
    open_action:
      - stepper.report_position:
          position: 0
          target: -1000
    close_action:
          position: 0
          target: 1000
    stop_action:
          target: !lambda return id(my_stepper).current_position;
    optimistic: true
# for manual adjustment of the initial setting position
switch:
    turn_on_action:
          position: 0
          target: -200
    turn_on_action:
          position: 0
          target: 200
    name: "Blind Encoder "
    pin_a: D2
    pin_b: D3
    filters:
     - or:
        - debounce: 0.1s
    resolution: 1
    min_value: 0
    max_value: 10
    on_value:
      then:
        - if:
            condition:
              lambda: return id(blind_encoder).state =+ 1 ;
            then:
              switch.turn_on: step_plus
        - if:
            condition:
              lambda: return id(blind_encoder).state =- 1 ;
            then:
              switch.turn_on: step_minus
the motor turns the same way regardless of encoder direction.
you people might learn something from here https://github.com/esphome/feature-requests/issues/566
