I went looking for some type of automation that would rotate through the list of available effects on a bulb without having to create a static list to go through. In the end I created this automation that only needs a text input helper to work. It also uses the list of effects reported back by the bulb to work through it, so it should adapt to any list of effects the entity lists as available (check in the developer panel under states).
Each bulb controlled with this automation will need a text input helper to be created with an initial value of none
so the automation can read the first on the list when it starts. In the code below it is called current_wiz_effect
This automation also has two triggered inputs that can be used to move forward or backwards through the list. The forward behavior is the default, but remember to add the trigger ID to your entries if you want to use the backwards functionality.
There are a few odd choices in here like adding a backtick to the end of the effect name to flag it. This is so it doesn’t match anything else in the list, and you can’t always rely on the bulb state when you have a finicky effect. The wiz bulb in question will switch to Rhythm but then a second later switch back to the previous effect. So if you send the trigger within 15 seconds of the last one, it relies on the helper value to determine the current effect. Otherwise it reads it from the bulb to find the next on the list.
Hope this helps someone out there, I’m curious how it does with different effect lists.
alias: Scene Switch 4 - Double / Long Press
description: "Rotate through available effects on RGB bulb"
- device_id: f05af41992bc235838ca1c6d5f078d2f
domain: zha
platform: device
type: remote_button_double_press
subtype: button_4
domain: zha
platform: device
type: remote_button_long_press
subtype: button_4
condition: []
- alias: >-
If over 15 seconds since the last call and there is an effect state on
bulb, set text helper to current effect. Helps skip over bad effects that
revert back to a previous effect.
if:
- condition: and
conditions:
- condition: template
value_template: >-
{% if state_attr('light.wiz_rgbw_tunable_42802c', 'effect') is defined %}
True
{% else %}
False
{% endif %}
alias: Is the bulb effect state not null
value_template: >-
{{ now() - this.attributes.last_triggered > timedelta(seconds=15) }}
alias: >-
Has it been over 15 seconds since the last trigger of this
automation
then:
- service: input_text.set_value
metadata: {}
value: "{{ state_attr('light.wiz_rgbw_tunable_42802c', 'effect') }}"
entity_id: input_text.current_wiz_effect
- if:
- condition: state
state: none
then:
- variables:
last_list_index: >-
{{ (state_attr('light.wiz_rgbw_tunable_42802c', 'effect_list')|length)-1 }}
alias: Get index of last item on the list
metadata: {}
value: >-
{{ state_attr('light.wiz_rgbw_tunable_42802c', 'effect_list')[last_list_index] }}
alias: >-
Use last item on the list as it will wrap to the first item in the
repeat loop
alias: If the effect text helper is set to none, assign it
metadata: {}
value: "{{ states('input_text.current_wiz_effect').split('`')[0] }}"
alias: >-
Ensure state helper doesn't have a backtick indicating it was found in the
loop below
- alias: Loop through effects list to find next effect on the list
repeat:
sequence:
- alias: Find current effect in list
if:
value_template: "{{ repeat.item == states('input_text.current_wiz_effect') }}"
alias: Current list item equals text input helper value
then:
- choose:
- conditions:
- condition: trigger
id:
- trigger_backwards
sequence:
- variables:
next_effect: |-
{% if repeat.index < 1 %}
{{ state_attr('light.wiz_rgbw_tunable_42802c', 'effect_list')[(state_attr('light.wiz_rgbw_tunable_42802c', 'effect_list')|length)-1] }}
{% else %}
{{ state_attr('light.wiz_rgbw_tunable_42802c', 'effect_list')[repeat.index-2] }}
{% endif %}
metadata: {}
value: "{{ next_effect }}`"
default:
- variables:
next_effect: >-
{% if repeat.index+1 > state_attr('light.wiz_rgbw_tunable_42802c', 'effect_list')|length %}
{{ state_attr('light.wiz_rgbw_tunable_42802c', 'effect_list')[0] }}
{% else %}
{{ state_attr('light.wiz_rgbw_tunable_42802c', 'effect_list')[repeat.index] }}
{% endif %}
metadata: {}
alias: Pick next effect direction by default
for_each: "{{ state_attr('light.wiz_rgbw_tunable_42802c', 'effect_list') }}"
- alias: >-
If we set a value in the repeat loop, set it in the input helper and send
to bulb
if:
value_template: |-
{% if '`' in states('input_text.current_wiz_effect') %}
True
{% else %}
False
{% endif %}
alias: Check if there is a backtick in the effect name
then:
metadata: {}
alias: Remove backtick and save new effect to text input helper
- service: light.turn_on
alias: Finally set the new effect name on the bulb
metadata: {}
effect: "{{ states('input_text.current_wiz_effect') }}"
device_id:
- a38abf815d0de7157dd768fc842d9274
mode: single
