Roth Touchline Classic – local, read-only Home Assistant integration (HACS)
I’ve published a community integration for the older Roth Touchline Classic underfloor-heating controllers.
Important: this is for the Classic generation with the local XML endpoint. It is not for Roth Touchline SL.
The integration is local-only and read-only: it polls the controller directly on your LAN and does not change heating settings or use a cloud service.
Features
  • Current room temperature for each discovered zone
  • Configured target temperature as a read-only sensor
  • Last-seen timestamp
  • UI configuration and support for multiple controllers
  • Configurable polling interval and zone limit
Requirements
  • Home Assistant 2026.7.2 or newer
  • A Roth Touchline Classic controller reachable from Home Assistant
  • The controller’s local XML API endpoint: /cgi-bin/ILRReadValues.cgi
Install with HACS
Configuration asks for the controller IP/host, port, maximum number of zones, and polling interval. Available zones are discovered automatically.
Links
Reports from users with different Classic controller firmware versions are welcome. This is a spare-time project, so responses may be slow. If something does not work, please include your Home Assistant version, controller model/firmware, and relevant logs in a GitHub issue.
