Hi
I have the Roth Touchline integration installation and it seems to work but the state is always “heat” even that temperature is above set, and that the Touchline controller is in holyday mode (can the controller mode be read?)
the error from the log is:
Source: components/climate/init.py:418
Integration: Home Assistant WebSocket API
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 130, in handle_call_service
connection.context(msg),
File “/usr/src/homeassistant/homeassistant/core.py”, line 1247, in async_call
task.result()
File “/usr/src/homeassistant/homeassistant/core.py”, line 1282, in _execute_service
await handler.func(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 213, in handle_service
self._platforms.values(), func, call, required_features
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 453, in entity_service_call
future.result() # pop exception if have
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 596, in async_request_call
await coro
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 484, in _handle_entity_call
await result
File “/usr/src/homeassistant/homeassistant/components/climate/init.py”, line 422, in async_set_hvac_mode
await self.hass.async_add_executor_job(self.set_hvac_mode, hvac_mode)
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/climate/init.py”, line 418, in set_hvac_mode
raise NotImplementedError()
NotImplementedError
I did update the Roth Touchline service so it supports the different modes, but I gave up on the pull request here: https://github.com/home-assistant/core/pull/32221 beacuse of all the comments (doing what he wrote, renders Roth Touchline pretty much useless).
I run Home Assistant 0.106.2 with my own version of Roth Touchline and it works just fine:
Thats a shame it is so hard to get PR through as
Actually the touchline is also able to cool, but haven’t heard about anyone doing that. But at least it can be Off(holyday mode)
It would be nice if the HVAC_action was CURRENT_HVAC_HEAT in case the set temperature was above actual temperature, and CURRENT_HVAC_IDLE if set temperatur was reached.
I decided to fix the issues from the previous PR and make a new one:
I have zipped the updated file to http://cm3.dk/climate.zip for anyone to try out. Please make a backup of the existing climate.py file.
I don’t see a way of getting the controller to report back, if it is heating (valve opened) or idling (valve closed). It’s just not in any of the attributes reported back from the system.
Thanks for new PR
No the Touchline don’t provide a state of the valves. But maybe the integration can calculate it based on set and target temp. Like mentioned here: Touchline
I also have some thermostats with IR temp sensor and the value is not exposed in controller. Thats a bommer.
I have just started using HA and i have a Roth Touchline plus, but when i try to add it to automation.yaml it does not show up, and i get errors in the log.
Maybe this integration has been deprecated, and is not working any more ?
When i restarted HA, it did not work and i get these lines in the error log.
2022-03-05 22:10:58 ERROR (MainThread) [homeassistant.components.climate] touchline: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 431, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 719, in async_device_update
await task
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/touchline/climate.py", line 84, in update
self.unit.update()
File "/usr/local/lib/python3.9/site-packages/pytouchline/__init__.py", line 60, in update
response = self._request_and_receive_xml(request)
File "/usr/local/lib/python3.9/site-packages/pytouchline/__init__.py", line 128, in _request_and_receive_xml
return xml(content)
File "/usr/local/lib/python3.9/xml/etree/ElementTree.py", line 1347, in XML
parser.feed(text)
xml.etree.ElementTree.ParseError: not well-formed (invalid token): line 1, column 190
Oh and just to add, i am running the latest 2018 firmware in the Roth Touchline plus controller
It works on my machine
This error is usually because HA is unable to reach the controller. Do you have it on different vlans?
Note: I have the old Touchline controller. don’t know if it works with Touchline plus (whatever that is)
I have no VLAN, everything is connected more or less directly.
The HA controller is connected to a 24 port ubiquiti switch, and the Touchline controller is connected to a 8 port Ubiquiti switch that is linked to the 24 port switch.
From the terminal on HA, i can ping 10.0.0.59 and i get a ping reply, and i know that this is the Roth controller, because it is plugged into port 6 on the 8 port switch, and when i click on it in the unifi controller, it says that it is 10.0.0.59
When i browse to 10.0.0.59 in a browser i get “Java Applet not shown by your browser. Java is either disabled or not present.” so it is responding, and the app also works fine.
Theoretically i could move the HA to a port in the 8 port switch to rule out that something is blocked between the 2 switches, but i have no problem with other equipment that runs on the 2 switches.
I checked the HA controller’s IPv4 settings, and it is set to “10.0.0.253/24” so it’s not a subnet problem as far as i can see, and if it were, a ping should not be succesful, from memory.
Yes it has been working flawlessly more or less since then. Sadly i can not remember what i did to make it work, or if it just started working by itself.
Has been pretty reliable as well.
Do you know for a fact the new SL version is also supported ?
