drpau
(Drpau)
November 21, 2022, 3:57am
1
Hi, i am trying to collect all my upstairs thermostats, and average them, and round them to 2 decimal places.
I have finally got the formatting correct (i think) and without the | round(2)
i get the right result, but as soon as i add that in, i get the final temperature to 3 decimal places.
Hoping you can advise, and point me in the right direction
Thank you
set upstairs_temp = (
states('sensor.ensuite_sensor_temperature') | float +
states('sensor.harper_s_thermostat_temperature') | float +
states('sensor.mia_s_thermostat_temperature') | float +
states('sensor.landing_thermostat_temperature') | float +
states('sensor.main_bedroom_thermostat_temperature') | float +
states('sensor.study_thermostat_temperature') | float
/ 6 | round (2)
{{upstairs_temp}}
(Taras)
November 21, 2022, 4:15am
2
Your template is rounding the number 6 only and not the entire calculation. Wrap the calculation in parentheses to make the round
filter round the calculation’s result.
set upstairs_temp = ((
/ 6) | round(2)
{{upstairs_temp}}
You should also supply the float
filter with a default value. Otherwise, if it receives a non-numeric value it will cause an error message.
If you’re simply trying to calculate the average, you should consider using the average
filter.
Reference: Templating - Numeric function and filters
drpau
(Drpau)
November 21, 2022, 4:31am
3
thank you very much. I have just done the addition ( and ) and that has worked. knew it would be something simple.
Yes I’m just trying to do the average of the room (next step is to create a custom sensor and graph that).
I will take a look at the link you referenced and see if i can work out the average, because that would be seemingly much more simple
drpau
(Drpau)
November 22, 2022, 2:39am
4
Hi @123 , thank you for the help yesterday. I am now getting this in my error log. Are you able to assist in how and why?
2022-11-22 13:35:01.545 ERROR (MainThread) [homeassistant.helpers.template_entity] TemplateError('ValueError: Template error: float got invalid input 'unknown' when rendering template '{% set upstairs_temp = (( states('sensor.ensuite_sensor_temperature') | float + states('sensor.harper_s_thermostat_temperature') | float + states('sensor.mia_s_thermostat_temperature') | float + states('sensor.landing_thermostat_temperature') | float + states('sensor.main_bedroom_thermostat_temperature') | float + states('sensor.study_thermostat_temperature') | float ) / 6) | round (2) %} {{upstairs_temp}}' but no default was specified') while processing template 'Template("{% set upstairs_temp = (( states('sensor.ensuite_sensor_temperature') | float + states('sensor.harper_s_thermostat_temperature') | float + states('sensor.mia_s_thermostat_temperature') | float + states('sensor.landing_thermostat_temperature') | float + states('sensor.main_bedroom_thermostat_temperature') | float + states('sensor.study_thermostat_temperature') | float ) / 6) | round (2) %} {{upstairs_temp}}")' for attribute '_attr_native_value' in entity 'sensor.upstairs_temperature'
drpau
(Drpau)
November 22, 2022, 2:45am
5
@123 i have just found your explaination here for someone else (here ) i will try add the float(0)
to all my floats in the template.
If thats the answer no need to reply yes i still need to move it to the average function
123
(Taras)
November 22, 2022, 3:19am
6
The error is due to what I explained in my first post:
If the sensor’s value is unknown
then float(0)
will report it as 0
. However that will, of course, affect the calculation of the average value.
