Having an already created theme, how and where to add the two new variables ha-card-border-radius and ha-card-background ?
I’d like to have some examples…
bumping this thread because I have tried adding ha-card-border-radius: ‘20px’
to my theme’s but it isn’t working… hoping for some guidance, please.
frontend:
themes:
slate:
# Main colors
ha-card-border-radius: '10px'
I have a themes.yaml in packages
@sparkydave did you do yours on a mobile? the quotes are WRONG (typical of iOS)
‘20px’ </=> '20px'
…actually I had just copy/pasted from another thread. My bad, I should have known something was up when the text colour seemed wrong in the IDE editor. Thanks for pointing it out, working now
If one has an existing theme, but only wants to tweak it slightly, is there a syntax that would allow a mix of e.g. setting the card radius and have a !include_dir_merge_named
For example, this is my themes section:
frontend:
themes: !include_dir_merge_named themes
Is there a way to set ha-card-border-radius: 10px
without having to define it for each theme? (Or perhaps stated differently: Can one mix !include
and still set values for specific keys?)
In my case, I’ve defined a custom light theme similar to the OP:
custom-light-mode:
But I also have the slate
theme installed (and automatically included with the !include
) and want to set the same card radius CSS on it.
I’m not sure whether I’m asking this in the right way, but I hope it’s clear what I’m trying to do.
Create a file in www called ThemeOveride.js with the following contents:
Idea stolen from https://gist.github.com/thomasloven/2a37152725c582fec4420ecedb65ebe3
Add this to your configuration.yaml
frontend:
extra_module_url:
- /local/ThemeOverride.js
And put the following into <config-dir>/www/ThemeOverride.js
document.documentElement.style.setProperty('--ha-card-border-radius', '10px');
Then in configuration.yaml put this:
frontend:
extra_module_url:
Restart HA and you’ll have the 10px rounded corners on all cards.
Excellent, that will do it, thanks.
I’m so using this to set a card background blur
Not working for me
It stopped working some time ago so you just need to add it to your themes
