using roborock s7 vmax. with roborock integration and Xiaomi vacuum map card, when i add the vaccum code i get not the same colors as here, and the pon & go and zones not working, get āservice not foundā
someone know?
wow ! can you share the security system card please? you use alarmo?
i copy and edit the Rounded.yaml.
but the toolbar still up, what is wrong?
Just have a look in my github repository.
its include the bottom bar code? what different yours from the original one?
also, all the custom cards are minimalist yaml style? I canāt add them like a custom card with the UI?
where do you see the version?
Copy the contents of this file from panhans repo over your existing rounded.yaml file (which should be in your themes folder):
Every once in a while, I get this shaded button background stuck issue. Anyone know what is causing this?
Also, any idea how to remove the bottom white bar?
Note, Iām using your Rounded.yaml file above.
how I make the white button sync to day\night screen? right now its white background and didnt change to black like the guide theme
Use background: var(ācontrast20)
Hi all,
Can someone give me a Yaml code to show both temperature and humidity on the sensor card? Currently it shows only the temperature but I would like to see both entities on 1 card.
Many thanks
so following Round by @panhans , Iām having trouble to add his card to the original Rounded dashboard I create.
**where should I enter this line? tton_card_templates: !include_dir_merge_named āui/templatesā
as I donāt have any YAML file for this dashboard. created it via UI.
I need to add it to the dashboard āRaw configuration editorā for example under all the views of the GUI, I need to add
button_card_template
when I add then the alarm card I get this:
so something is missing
@ald112 In your Raw configuration editor you have button_cards_template:
instead of button_card_templates:
I added āsā. Also moved this block to the top of the page, added also ābaseā section.
Now i get
So i add the block of state engine also. Still getting this error.
There is special order of the blocks?
Hey @LE0N ,how did you create the date and time to each zone of the vacuum? Last clean.
Also, i dont succeed to make the map one color, and i copy your code (i have roborock s7)
@ald112 Do u have installed GitHub - elax46/custom-brand-icons: Custom brand icons for Home Assistant ?
yes exactly
