🟣 Rounded - Dashboard guide
Good morning!
Looking for a bit of help, I’m overlooking something but I can’t figure it out.
I want to have a welcome message on my dashboard using the rounded card templates, ensuring it fits the overall look and feel and is integrated nicely into my overall dashboard.
In this case, I’m using the templates created by @panhans, in particular the title_card card.
Have a sensor to give me a random message and would like to have the title showcase that state, see below.
>-   {{ states('sensor.greeting_time') }}, {{ user }}{{["!", ".", ". 😉", "! 👍",   ". 🤩"] | random }}
The whole code of the card:
type: custom:button-card
template: title_card
  ". 🤩"] | random }}
label: #test
show_label: false
Anybody has a tip on how to display it correctly :blush:
Can I get the code for the changes you made to the graph card
Thanks for this.
It’s great. I made some of my own if people want the code let me know.
Not sure if the font colors are correct so if someone can help with that it would be great
did you figure out how to solve it?
someone succeed in creating slider of temperture and volume of light in the same window?
Would love the code!
Here you go.
Let me know how it goes
label: '[[[ return entity.attributes.current_temperature + "°C"]]]'
show_icon: false
show_label: true
show_name: false
show_state: true
entity: climate.living
tap_action:
  action: toggle
  haptic: medium
hold_action:
  action: more-info
  haptic: medium
custom_fields:
  button:
    card:
      type: custom:mushroom-chips-card
      alignment: center
      styles:
        card:
          - background: var(--contrast2)
          - font-family: HK Nova
          - padding: 16px
          - max-width: 50px
      chips:
        - type: template
          tap_action:
            action: call-service
            service: climate.set_hvac_mode
              entity_id: '[[[ return entity.entity_id; ]]]'
              hvac_mode: heat
            haptic: medium
          icon: mdi:fire
          icon_color: |
              if (entity.state == 'heat') {
                return 'red';
          card_mod:
            style: |
              ha-card {
                padding: 0 5px;
                --chip-icon-size: 16px;
              {% if is_state('climate.living', 'heat') %}
                --chip-background: rgba(255,205,210,.40);
              {% else %}
                --chip-background: rgba(100,100,100,0.10);
              {% endif %}
        - type: template
          tap_action:
              hvac_mode: cool
            haptic: medium
          icon: mdi:snowflake
          icon_color: |
              if (entity.state == 'cool') {
                return 'blue';
          card_mod:
            style: |
              ha-card {
                padding: 0 5px;
              {% if is_state('climate.living', 'cool') %}
                --chip-background: rgba(164,210,255,1);
              {% else %}
              {% endif %}
        - type: template
          tap_action:
            service: climate.turn_off
            haptic: medium
          icon: mdi:power
          card_mod:
            style: |
              ha-card {
                padding: 0 5px;
styles:
  grid:
    - grid-template-areas: '"l" "s" "button"'
    - grid-template-columns: 1fr
    - grid-template-rows: 1fr min-content min-content
  card:
    - padding: 16px
    - max-width: 190px
    - '--mdc-ripple-press-opacity': 0
  img_cell:
    - justify-self: start
    - width: 24px
  label:
    - font-size: 24px
    - margin: 4px 0 8px 0
    - color: var(--contrast20)
  state:
    - font-size: 14px
    - margin: 4px 0 22px 0
    - color: var(--contrast8)
    - text-transform: uppercase
state:
  - value: heat
    styles:
      card:
        - background: var(--red)
      icon:
        - color: var(--black)
      name:
  - value: cool
    styles:
      card:
        - background: var(--blue)
      icon:
      name:
Nice, thanks!
Sure, I’ll grab it for you when I’m home. I’ve been away with my new born in the hospital. Haven’t had much chance to visit here.
EDIT: Here are the changes I made to the graph. Note it looks good on my iphone…you might have to play around with some numbers for your specific setup.
      /* Graph card style */
      .graph {
        background: var(--blue-tint);
        display: flex;
        overflow: hidden; /* Temporary fix for graph overflow bug */
        height: 120px;
      .graph .name {
        font-size: 12px;
        line-height: 18px;
        background: var(--black);
        color: var(--white);
        padding: 6px 10px;
        border-radius: 100px;
        z-index: 1;
      .graph .icon {
        display: none;
      .graph .info {
        margin-top: 0;
        padding: 24px 24px 0 24px;
        order: 1;
      .graph .value::after {
        content: '°';
      .graph .measurement {
        visibility: hidden !important;
      .graph hui-graph-header-footer {
        order: 3;
      .graph .header {
        padding: 0 24px;
        order: 2;
        margin: 4px 0 -48px 0;
        z-index: 1;
Congrats on becoming a parent! All the best :slight_smile:
someone know how to create slider for light temperature?
same as dynamic slider for current open lights?
thanks!!
hey, can you explain what you did in your animal page? maybe I will use it (:
Would it be possible to post the code for the cover rounded card that shows the position of the shutter on the slider? Can’t get it to work sadly :slight_smile:
update: found your code and applied it in a pop-up card, functionality works perfectly but the popup card doesnt inherit the same layout as the rounded cards. anyone has any advice on how to apply the same layout from the rounded theme to the popup card?
the covers/shutters all 6 of them show up in the popup but don’t have a separate button layout
code + screenshots below:
code for the “rolluiken button card”
icon: phu:blind-tilt-open
entity: cover.open_ramen
show_label: false
tap_action:
  action: more-info
hold_action:
  action: more-info
double_tap_action:
  action: none
  haptic: medium
state:
  - value: 'open'
    styles:
      card:
        - background-color: var(--yellow)
        - box-shadow: none
      icon:
      name:
      label:
        - opacity: '0.5'
  - value: 'closed'
    styles:
      card:
        - box-shadow: none
      icon:
        - width: 24px
      name:
      label:
        - color: var(--contrast9)
styles:
  icon:
    - width: 24px
  img_cell:
    - justify-content: flex-start
    - margin-top: '-4px'
  name:
    - font-size: 14px
    - margin-bottom: 0px
  card:
    - height: 84px
    - border-radius: 24px
    - padding: 12px 0 12px 14px
    - box-sizing: border-box
  label:
    - font-size: 14px
code for the popup card itself
type: custom:popup-card
card:
  square: false
  type: grid
  cards:
    - type: custom:mushroom-cover-card
      entity: cover.screen_mbr
      show_position_control: true
      show_buttons_control: true
      card_mod:
        style: |
          ha-card {
            {% if states['cover.livingroom'].state == 'open' %}
            background-color: var(--blue);
            :host {
              --primary-text-color: black;
            {% elif states['cover.livingroom'].state == 'closed' %}
            background-color: var(--red);
            :host {
            {% elif states['cover.livingroom'].state == 'opening' %}
            background-color: var(--yellow);
            :host {
            {% elif states['cover.livingroom'].state == 'closing' %}
            background-color: var(--orange);
            {% endif %}
      entity: cover.velux_mbr
      show_tilt_position_control: false
      card_mod:
        style: |
          ha-card {
            {% if states['cover.kitchen'].state == 'open' %}
            :host {
            {% elif states['cover.kitchen'].state == 'closed' %}
            :host {
            {% elif states['cover.kitchen'].state == 'opening' %}
            :host {
            {% elif states['cover.kitchen'].state == 'closing' %}
            {% endif %}
      entity: cover.screen_dressing
      card_mod:
        style: |
          ha-card {
            :host {
            :host {
            :host {
            {% endif %}
      entity: cover.velux_badkamer
      card_mod:
        style: |
          ha-card {
            :host {
            :host {
            :host {
            {% endif %}
      entity: cover.velux_gastenkamer
      card_mod:
        style: |
          ha-card {
            :host {
            :host {
            :host {
            {% endif %}
      entity: cover.velux_bureau
      card_mod:
        style: |
          ha-card {
            :host {
            :host {
            :host {
            {% endif %}
  columns: 2
dismissable: true
title: Rolluiken
right_button: Alles op
left_button: Alles neer
left_button_action:
  service: cover.close_cover
    entity_id:
      - cover.screen_dressing
      - cover.screen_mbr
      - cover.velux_badkamer
      - cover.velux_bureau
      - cover.velux_gastenkamer
      - cover.velux_mbr
right_button_action:
  service: cover.open_cover
    entity_id:
      - cover.screen_mbr
      - cover.velux_mbr
please do so, also looking forward to it :slight_smile:
Does anyone managed to recreate the 30 Sec Back/Forward button in the Sonos card?
I mean the card/button it self is just a simple copy. But anyone been succesfull with the script to really rewind or forward the music which is playing?
Thanks for all the help so far in this topic & especially @LE0N for his awesome design!
Anybody? :pray:
This won’t work because your code is jinja specific while custom button card is javascript. It’s probably possible with JavaScript, but I don’t have the knowledge for this.
Thanks for the reply. Also not sure how to, so was hoping that somebody would but no luck yet. Will keep trying
someone created energy consume \ cost ROUNDED card? and want to share? (:
