🟣 Rounded - Dashboard guide
Thanks you so much :smiling_face_with_three_hearts:
I will definitely take a look at it and try it out :slight_smile:
You might also want to create a separate thread for this in the forum @Arroma . :slight_smile:
I think that more people will be interested in the design and may have questions and further ideas :wink:
Then I’ll open a thread, thanks for the suggestion and above all for your interest!
Trying to implement this wonderful theme to my setup and got stuck when adding the lights cards. I got this error message:
Capture d’écran 2024-02-01 à 10.55.11
Can anyone help ?
did you set entity in your card?
Put the whole card code here please
That was the mistake, I changed the entity on one place but not on the other one :confused:
My attempt on a HVAC card for my Aquaras, which doesn’t break the whole design.
Though I can not decide which version I will use
Here a different variant, which has the swipe card feature included and matches the rounded version.
Super nice! Can you share you code? Would go for both, as it wouldn’t bother me to have the temperature curve and the state shown below in the button card.
Sure. Here you go. Its my decluttering-card template for the first variant. Its using mini-graph-card and custom-button-card.
Be aware,that the color variables are related to leon rounded theme.
You need to make a button, which just turns on and off your climate entity.
  material_hvac:
    default:
      - entity: climate.your_climate
      - sensor_temp: here temperature sensor
      - sensor_hum: here humidity sensor
      - bg_color_control: var(--primary-background-color)
      - bg_color_graph: var(--primary-background-color)
      - bg_color_off_graph_value: var(--primary-text-color)
      - bg_color_on_graph_value: var(--red)
    card:
      type: custom:button-card
      entity: '[[entity]]'
      icon: mdi:thermostat
      tap_action:
        action: toggle
        haptic: medium
      show_icon: false
      show_name: false
      custom_fields:
        graph:
          card:
            type: custom:mini-graph-card
            entities:
              - entity: '[[sensor_temp]]'
                color: red
                index: 0
                align_state: left
              - color: var(--blue)
                entity: '[[sensor_hum]]'
                index: 0
                show_state: true
                y_axis: secondary
                align_state: right
            show:
              icon: false
              labels: false
              legend: true
            card_mod:
              style: |
                ha-card {
                  background-color:
                    {%- set hvac = states('[[entity]]') %}
                    {%- if hvac == 'heat' %}[[bg_color_on_graph_value]]
                    {%- else %}[[bg_color_off_graph_value]]
                    {%- endif %};
                  border-radius: 24px;
                  font-size: 28px !important;
                .graph {
                  background: [[bg_color_graph]];
                  display: flex;
                  overflow: hidden; /* Temporary fix for graph overflow bug */
                .graph__legend {
                  margin-top: 0px !important;
                  justify-content: center !important;
                .graph__legend__item {
                  font-size: 10px !important;
                  line-height: 16px !important;
                  padding: 6px 10px !important;
                  border-radius: 100px !important;
                  z-index: 1 !important;
                .states{
                  height: 1.5rem;
                  font-size: 12px;
                  font-weight: 500 !important;
                  color:
                    {%- if hvac == 'heat' %}var(--white) !important
                    {%- else %}var(--primary-background-color) !important
                    {%- endif %};
                .state__value {
                  font-family: 'Montserrat'!important;
                .state__uom {
                  font-size: 12px !important;
                  color: var(contrast2);
                  align-self: flex-end !important;
                .states--secondary {
                  color:  {%- set hvac = states('[[entity]]') %}
                    {%- if hvac == 'heat' %}var(--black) !important
                    {%- else %}var(--contrast10) !important
                    {%- endif %};
                  align-self: flex-start !important;
        button_up:
          card:
            icon: mdi:chevron-up
            show_name: false
            tap_action:
              action: call-service
              service: climate.set_temperature
              service_data:
                entity_id: '[[entity]]'
                temperature: |
                    var temp = ((states['[[entity]]'].attributes.temperature) + 0.5);
                      return temp;
            styles:
              icon:
                - width: 28px
                - color: |
                      if (states['[[entity]]'].state === 'heat') {
                        return 'var(--contrast20)';
                      } else {
                        return 'var(--contrast8)';
              card:
                - background: |
                        return 'var(--contrast2)';
                      } else {
                        return 'none';
                - animation: |
                        return 'blink 3s';
        button_target_temp:
          card:
            show_name: true
            show_state: false
            show_icon: false
                var temp = (states['[[entity]]'].attributes.temperature);
                  return temp;
            styles:
              name:
                - font-size: 21px
                - background: none
                - color: |
                      } else {
                - border-radius: 50px
                - padding: 8px
              card:
                - background: none
                - animation: |
                        return 'blink 3s';
        button_down:
          card:
            icon: mdi:chevron-down
            show_name: false
            tap_action:
              service_data:
                temperature: |
                    var temp = ((states['[[entity]]'].attributes.temperature) - 0.5);
                      return temp;
            styles:
              icon:
                - width: 28px
                - color: |
                      } else {
              card:
                - background: |
                      } else {
                        return 'none';
                - animation: |
                        return 'blink 3s';
      styles:
        grid:
          - grid-template-columns: 80% 20%
          - grid-template-areas: '"graph button_up" "graph button_target_temp" "graph button_down"'
          - grid-template-rows: 1fr 1fr 1fr
        card:
          - height: 100%
          - padding: 0px 0px 0px 0px
          - margin: 0px 0px 0px 0px
          - background: '[[bg_color_control]]'
        custom_fields:
          button_up:
            - width: 80%
            - padding: 0
            - margin: 0
            - justify-self: center
            - align-self: center
          button_target_temp:
            - width: 100%
            - padding: 0
          button_down:
            - width: 80%
            - padding: 0
            - margin: 0
          graph:
            - heigth: 100%
            - width: 100%
            - padding: 0
            - margin: 0
            - overflow: visible
Thanks will have a look!
can someone help me. I don get it
brave_Zx2bJhO1qk
icon: mdi:bed-king-outline
entity: sensor.rt_schlafzimmer_aktuelle_temperatur
show_state: true
tap_action:
  action: navigate
  navigation_path: '#pop-up-schlafzimmer'
custom_fields:
  btn:
    card:
      type: custom:mushroom-chips-card
      chips:
        - type: template
          tap_action:
            action: toggle
          icon: mdi:ceiling-light
          entity: light.00169be9a0f15a_2
          card_mod:
            style: |
              ha-card {
                --chip-background: {{ 'var(--red)' if is_state('light.00169be9a0f15a_2', 'on') else 'var(--contrast2)' }};
                padding: 0px!important;
                border-radius: 100px!impportant;
                --primary-text-color: var(--contrast20);
        - type: template
          tap_action:
            action: toggle
          icon: mdi:led-strip-variant
          card_mod:
            style: |
              ha-card {
        - type: template
          tap_action:
            action: toggle
          icon: mdi:weather-windy
          card_mod:
            style: |
              ha-card {
  btn1:
    card:
      chips:
        - type: template
          tap_action:
            action: toggle
          icon: mdi:fan
          card_mod:
            style: |
              ha-card {
                --chip-background: {{ 'var(--green)' if is_state('light.00169be9a0f15a_2', 'on') else 'var(--green-tint)' }};
styles:
  grid:
    - grid-template-areas: '"n btn1 btn" "s btn1 btn" "i btn1 btn"'
    - grid-template-columns: 1fr min-content min-content
    - grid-template-rows: min-content min-content 1fr
  img_cell:
    - justify-content: start
    - position: absolute
    - width: 100px
    - height: 100px
    - left: 0
    - bottom: 0
    - margin: 0 0 -20px -20px
    - background: var(--contrast10)
    - border-radius: 500px
  icon:
    - width: 45px
    - color: var(--contrast1)
    - opacity: '0.6'
  card:
    - padding: 10px 0px 10px 10px
    - background-color: var(--contrast4)
  custom:fields:
    btn:
      - justify-self: end
      - align-self: start
    btn1:
      - justify-self: end
      - align-self: start
  name:
    - justify-self: start
    - align-self: start
    - font-size: 13px
    - font-weight: 500
    - color: var(--contrast20)
  state:
    - min-height: 80px
    - align-self: start
    - font-size: 11px
    - opacity: '0.7'
solution:
show_name: false
show_state: false
show_icon: true
tap_action:
  action: navigate
styles:
  card:
  grid:
    - grid-template-areas: '"name name btn" "state btn1 btn" "icon btn1 btn"'
    - grid-template-columns: 3fr min-content min-content
    - grid-template-rows: 1em 1em 1fr
  img_cell:
    - width: 80px
    - height: 80px
    - left: 0
    - bottom: 0
    - margin: 0 0 -15px -15px
  icon:
    - width: 45px
    - opacity: '0.6'
  custom_fields:
    name:
      - align-self: start
      - background: none
    state:
      - align-self: start
      - background: none
    btn1:
      - align-self: end
      - justify-self: end
      - padding-right: 8px
    btn:
      - align-self: end
      - justify-self: end
    icon:
      - align-self: start
custom_fields:
  name:
    card:
      styles:
        card:
          - font-size: 13px
          - font-weight: 500
          - background: none
  state:
    card:
          return states['sensor.rt_schlafzimmer_aktuelle_temperatur'].state + '<span style="font-size:0.7em">°C</span>';
      styles:
        card:
          - font-size: 11px
          - background: none
          - opacity: '0.7'
  btn:
    card:
      chips:
        - type: template
          tap_action:
            action: toggle
          card_mod:
            style: |
              ha-card {
        - type: template
          tap_action:
            action: toggle
          card_mod:
            style: |
              ha-card {
        - type: template
          tap_action:
            action: toggle
          entity: input_boolean.helfer_luften_schlafzimmer
          card_mod:
            style: |
              ha-card {
                --chip-background: {{ 'var(--blue)' if is_state('input_boolean.helfer_luften_schlafzimmer', 'on') else 'var(--contrast2)' }};
                {% if is_state('input_boolean.helfer_luften_schlafzimmer', 'on') %}
                animation: blinkAnimation 1s infinite; /* Blinken mit einer Sekunde Dauer */
                {% endif %}
              @keyframes blinkAnimation {
                0% {
                  --chip-background: var(--blue);
                50% {
                  --chip-background: var(--contrast3);
                100% {
  btn1:
    card:
      chips:
        - type: template
          tap_action:
            action: toggle
          icon: mdi:fan
          card_mod:
            style: |
              ha-card {
                --chip-background: {{ 'var(--green)' if is_state('light.00169be9a0f15a_2', 'on') else 'var(--contrast2)' }};
Is this still working as of Feb 2024? There are a few things that don’t seem to work for me, one of those being the nav bar at the bottom. My nav bar is still at the top.
EDIT
I got this working. The problem is at install I skipped the following step to set this as my default theme system wide:
  1. Next, open the service named “Home Assistant Frontend: Set theme” and run the service twice with both the “Dark” and “Light” modes checked.
This didn’t work for me using the old group definition, but I was able to get it to work with the light group type (posting here for others in the future troubleshooting the same thing).
Example of my group
light:
  - platform: group
    name: "New Downstairs Lights"
    entities:
      - light.kitchen_ceiling
      - light.coffee_bar_light_light
      - light.sink_light_light
      - light.living_room
      - light.dining_room
      - light.downstairs_hallway_light_light_2
And here is my template using that group:
    lights:
      on_downstairs_lights:
        friendly_name: "On Downstairs Lights"
        level_template: >
          {% set data = namespace(numbers=[]) %}
          {% for s in state_attr('light.new_downstairs_lights', 'entity_id') %}
            {% if is_state(s, 'on') %}
              {% set data.numbers = [state_attr(s, "brightness")] + data.numbers %}
            {% endif %}
          {% endfor %}
          {{data.numbers|average|round(0)}}
        value_template: >
          {%- set data = namespace(res="off") -%}
              {%- set data.res = "on" -%}
            {% endif %}
          {%- endfor -%}
          {{data.res}}
        temperature_template: >
            {% if state_attr(s, "color_temp") %}
              {% set data.numbers = [state_attr(s, "color_temp")] + data.numbers %}
            {% endif %}
          {% endfor %}
        turn_on:
          - service: light.turn_on
              entity_id: light.new_downstairs_lights
        turn_off:
          - service: light.turn_off
        set_level:
              # wat te doen als alles uit staat? If statement om alles aan te zetten
              entity_id: "{{ expand('light.new_downstairs_lights') | selectattr('state','eq','on') | map(attribute='entity_id') | join(',') }}"
              brightness: "{{ brightness }}"
        set_temperature:
              color_temp: "{{ color_temp }}"
Since they’re both of the “light” type, they are under the same light block. See below for the full code block with both of them:
light:
  - platform: group
    entities:
      - light.living_room
      - light.dining_room
    lights:
        level_template: >
            {% endif %}
          {% endfor %}
        value_template: >
            {% endif %}
          {%- endfor -%}
          {{data.res}}
            {% endif %}
          {% endfor %}
        turn_on:
        turn_off:
        set_level:
        set_temperature:
I’m unsure if I was supposed to put this into a groups.yaml file but I put it in my configuration.yaml and it’s working so I’m going to leave it unless I find out some optimization for using groups.yaml. If I start declaring a lot of groups in YAML I will probably move it so I don’t clutter my configurations.yaml but for now not going to change something that’s working.
Thanks everyone and let’s keep contributing to this thread to make sure this awesome theme is still usable for anyone just installing it!
Could you post the decluttering template for the second variant? Looks really nice
Sorry for my late reply. I will make a decluttering card of my latest version. I’ve “translated” Leonz version to one, which is using Mini-Graph card, so I can apply colors to the graph-lines.
Has also the swipe card feature
This is my latest project. I made my old washing maschine “smart” with a smart plug. The available automations, did not fit my needs as I wanted to create a nice card.
Now, I’ve created template sensors to check the power consumption (with two thresholds on and off) and return if it’s starting, washing, finishing and end. Also the remaining time (manually set average running time in the sensor) and end time. This card is the result. Its a button to turn off and on the plug and if it’s on, it shows the state of the washing maschine.
Thanks to some nice scripts Leon showed on his YouTube channel!
Waiting for the code :innocent::innocent::innocent:
Sure. Here is my code for the 3 template sensors. The card needs all of them to work. If you dont want the timer or end -time, you csn just use the first template sensor alone and work with the attributes.
my threshold are set
start: 7 (watt)
End: 5 (watt)
the 2 values 30 are the time it needs to detect the thresholds.
If the sensor detects start >= 30 (s) the attribute cycle switches from starting to washing.
if it detects end for >= 30 (s) it switches from finishing to end.
the last sensor has number 59 inside. Thats the average running time of our washing mashine.
##### Waschmaschine #####
  sensors:
    waschmaschine_status:
      friendly_name: "Waschmaschine Status"
      value_template: >-
        {% set power = states('sensor.steckdose_waschkuche_power') | float %}
        {% set cycle_state = state_attr('sensor.waschmaschine_status', 'cycle') %}
        {% set threshold_start = 7 %}
        {% set threshold_end = 5 %}
        {% if cycle_state == 'washing' %}
          {% set threshold_start = threshold_end %}
        {% endif %}
        {% if power > threshold_start %}
          on
        {% elif power <= threshold_end %}
          off
        {% endif %}
      attribute_templates:
        cycle: >-
          {% if is_state('sensor.waschmaschine_status', 'on') %}
            {% if (as_timestamp(now()) - as_timestamp(states.sensor.waschmaschine_status.attributes.triggered)) >= 30 %}
              washing
            {% else %}
              starting
            {% endif %}
          {% elif is_state('sensor.waschmaschine_status', 'off') %}
              end
            {% else %}
              finishing
            {% endif %}
          {% else %}
            unknown
          {% endif %}
        running_end: >-
           {% if is_state_attr('sensor.waschmaschine_status', 'cycle', 'washing') or
              is_state_attr('sensor.waschmaschine_status', 'cycle', 'finishing') %}
              running
            {% else %}
              end
            {% endif %}
        triggered: >-
          {{ as_timestamp(states.sensor.waschmaschine_status.last_changed) | timestamp_custom('%Y-%m-%d %H:%M:%S', true) }}
  sensors:
    waschmaschine_running:
      friendly_name: "Waschmaschine Running"
      value_template: >-
              running
            {% else %}
              end
            {% endif %}
  sensors:
    waschmaschine_timer:
      friendly_name: "Waschmaschine Timer"
      value_template: >-
        {% if is_state('sensor.waschmaschine_running', 'running') %}
            on
        {% else %}
            off
        {% endif %}
        triggered: >-
          {{ as_timestamp(states.sensor.waschmaschine_timer.last_changed) | timestamp_custom('%Y-%m-%d %H:%M:%S', true) }}
        remaining: >-
            {% if is_state('sensor.waschmaschine_timer', 'off') %}
                00:00:00
              {% else %}
                {% set remaining_time = 59 * 60 %}
                {% set time_passed = as_timestamp(now()) - as_timestamp(states.sensor.waschmaschine_timer.attributes.triggered) %}
                {% set remaining_seconds = remaining_time - time_passed %}
                {% if remaining_seconds > 0 %}
                  {{ remaining_seconds | timestamp_custom('%H:%M:%S', false) }}
                {% else %}
                  00:00:00
                {% endif %}
              {% endif %}
        remaining_perc: >-
            0
          {% else %}
            {% set total_time = 59 * 60 %}
            {% set remaining_seconds = total_time - time_passed %}
            {% set remaining_perc = (remaining_seconds / total_time) * 100 %}
            {% if remaining_perc > 0 %}
              {{ remaining_perc | round(2) }}
            {% else %}
              0
            {% endif %}
          {% endif %}
        end_time: >-
          {{ (as_timestamp(states.sensor.waschmaschine_timer.attributes.triggered) + remaining_time) | timestamp_custom('%Y-%m-%d %H:%M:%S', true) }}
