Thanks that worked
But as far as i can see, the spacing between the 4 grids, there is a bigger gap with my own grids?
Thanks that worked
Worked, great job !
Thanks.
Works perfectly for brightness and color temperature, is there also a solution to change the color uniformly?
Has anyone managed to do this?
Greetings
Moss
I have created a button and want to toggle it to turn on a switch. however, the toggle is not working:
type: custom:button-card
icon: mdi:water-boiler
aspect_ratio: 1/1
tap_action:
action: toggle
haptic: medium
service: siwtch.turn_off
entity_id: switch.sonoff
What am i doing wrong?
siwtch dont work
Try switch.toggle
omg haha thanks!
Thanks for this. Looks good. I’ll definitely be ‘stealing’ parts of this.
Just a heads up for you in Rounded.yaml
app-header-selection-bar-color: transparant
→ app-header-selection-bar-color: transparent
Anyone knows why on stack-in-a-card, the borders does not work?
type: custom:vertical-stack-in-card
cards:
- square: false
columns: 5
type: grid
cards:
- type: custom:button-card
icontype: custom:button-card
icon: mdi:power
entity: media_player.ytube_music_player
show_name: false
aspect_ratio: 1/1
tap_action:
action: call-service
haptic: success
service: media_player.toggle
service_data:
entity_id: media_player.ytube_music_player
styles:
card:
- border-radius: 24px
- background: var(--green)
icon:
- width: 32px
- color: var(--black)
state:
- value: playing
styles:
card:
- background: var(--red)
icon: mdi:play
show_name: false
tap_action:
haptic: medium
service: script.youtubemusic_play_pause
aspect_ratio: 1/1
styles:
icon:
- width: 32px
- color: var(--green)
card:
- background-color: var(--contrast4)
state:
- value: playing
icon: mdi:pause
styles:
card:
- background-color: var(--yellow)
- type: custom:decluttering-card
template: card_players
variables:
- entity: media_player.ytube_music_player
What’s that?
I have just noticed that the temperature slider goes in the other direction than it is usual in the more-info dialogues of Homeassistant. There it goes from left (warm) to right (cold) colour temperature.
I have therefore set the temperature slider template to inverse: true
under the my-slider-v2 options and have also inverted the colour gradients for temperature
and temperature-tint
in the theme .yaml file. Just in case anyone else notices this. So it’s quite easy to change
Unfortunately, the current solution with the dynamic template light groups, for switched-on lights, in combination with the sliders is somewhat unreliable for me. For the brightness it works wonderfully, but for the colour temperature the slider jumps back and forth, and usually does not manage to apply the desired colour temperature. Does anyone else have this problem?
nvmd. it was because of my inverse: true
setting under the my-slider-v2 options. Instead I had to use flipped: true
BTW: @LE0N: Which custom font are you using?
Thank you! Kinda works, but I guess it’s a tad too much
Works better if you just leave the brightness section as it is. At least as long as you don’t switch the light to White:
No Idea haha, I removed and nothing changed, maybe a misswriting.
Too bad. Wondered, if it is a hidden feature
Hi @LE0N !
Thank you so much for sharing your awesome dashboard theme. It looks soo clean.
Could you tell which font are you using in yours dashboard? It looks really cool.
I want to add a label with the tempature tike @CM000n has done with his light button card.
But for some reason the label isnt popping up in the card.
What is wrong?
icon: mdi:floor-lamp-dual
label: '[[[ return states[''sensor.temperatuur_garage''].state + '' °C'' ]]]'
entity: light.woonkamer_lampen
tap_action:
action: toggle
haptic: medium
hold_action:
action: more-info
haptic: medium
custom_fields:
slider:
card:
type: custom:my-slider-v2
colorMode: brightness
styles:
container:
- background: none
- border-radius: 100px
- overflow: visible
card:
- height: 16px
- padding: 0 8px
- background: |
if (entity.state == "on") return "linear-gradient(90deg, rgba(255,255,255, 0.3) 0%, rgba(255,255,255, 1) 100%)";
else return "var(--contrast4)";
track:
- overflow: visible
- background: none
progress:
- background: none
thumb:
- background: |
if (entity.state == "on") return "var(--black)";
if (entity.state == "off") return "var(--contrast20)";
else return "var(--contrast8)";
- top: 2px
- right: '-6px'
- height: 12px
- width: 12px
styles:
grid:
- grid-template-areas: '"i" "n" "slider"'
- grid-template-columns: 1fr
- grid-template-rows: 1fr min-content min-content
card:
- font-family: In case of a custom font, otherwise you can remove this line
- background: var(--contrast2)
- padding: 16px
- '--mdc-ripple-press-opacity': 0
img_cell:
- justify-self: start
- width: 24px
icon:
- width: 24px
- height: 24px
- color: var(--contrast8)
name:
- font-size: 14px
- margin: 4px 0 12px 0
state:
- value: 'on'
styles:
card:
- background: var(--yellow)
icon:
name:
- value: 'off'
styles:
icon:
- color: var(--contrast20)
name:
You have to set show_label: true
according to button card documentation:
Besides the show_label: true
setting you sould also specify a dedicated place with l
for the label in the card styles. In my case for my navigation buttos, for example, it is like this: homeassistant/rounded.yaml at main · CM000n/homeassistant (github.com)
No, not realy. Now you are using a ‘light’ area in the card grid style but have only a ‘slider’ configured under custom_fields Please think twice, before you copy & paste code and sharing it afterwards
any rounded design ideas for cover and climate cards?
Thank you
Hope this becomes an addon / cards to make it easier like mushroom!
