I’ve got under sensor
- platform: systemmonitor
resources:
- type: load_1m
but I get a number like 0.9835023570252 which is a bit too long.
I think that I need to use
value_template: "{{ states.sensor.load_1m | round(2)}}"
But do I need to create a new extra sensor to display the rounded load (which is not nice at all), or can I tweak the display of the load as it is now?
I think you may need to create a Template Sensor, although there may be another way I’m not aware of. If you do, I’d suggest:
value_template: "{{ states('sensor.load_1m') | float | round(2) }}"
Or at least:
value_template: "{{ states.sensor.load_1m.state | round(2) }}"
Yes I wanted to avoid to have two sensors with the load on my dashboard.
I think that I can replace it with
- platform: command_line
command: cat /proc/loadavg|cut -d' ' -f1
scan_interval: 60
command: cat /proc/loadavg|cut -d' ' -f2
scan_interval: 60
command: cat /proc/loadavg|cut -d' ' -f3
scan_interval: 60
but it’s a shame to no being able to use the systemmonitor sensor…
Also I’m not sure how python gives a load with many many digits after the comma, while /proc/loadavg just gives 2 digits after the comma.
MikeVR
September 12, 2018, 12:57am
4
So, it’s not possible with systemmonitor sensor at all? (hiding main sensor not variant)
fickK
(Filip Vyskočil)
September 5, 2019, 12:12pm
5
customize.yaml not working
sensor.load_1m:
value_template: '{{ states.sensor.load_1m.state | round(1)}}'
I am using second sensor:
sensors:
load:
value_template: '{{ states.sensor.load_1m.state | round(2)}} {{ states.sensor.load_5m.state | round(2)}} {{ states.sensor.load_15m.state | round(2)}}'
