I am trying to figure out 2 things:
No decimal places, e.g., 99%, 100%.
Round to the nearest whole number, e.g., if 99.2% the value would be 99% whereas if the value is 99.5%, the result would be 100%.
"{{ (states('sensor.b3_solar_production') | float / states('sensor.b3_house_consumption') | float * 100 | round(2)) }}"
Any ideas?
Thanks All
I tried this, however it seems to produce decimal places whenever the value goes above 100%, which can happen for a few seconds as the CTs catch up.
finity
December 4, 2022, 7:30pm
4
Have you tried βround(0)β?
Also, the way you are doing it now is only rounding the 100.
Move your last ) to right behind the 100 and it will round everything.
Just a question. How would I prevent this value ever going above 0 or 100?
As the inverter changes etc, the value currently goes above 100 and less than 0, before stabilising.
How can this be achieved?
I need to add min and max values essentially.
Thanks.
finity
December 5, 2022, 3:57pm
7
try this:
{% set value = (states('sensor.b3_solar_production') | float / states('sensor.b3_house_consumption') | float * 100) | round(2) %}
{% set limits = [0, value, 100] %}
{% set constrained_value = (limits | sort)[1] %}
{{ constrained_value }}
you could probably combine the whole template into one line but I spelled it out so you could see what itβs doing.
Worked a treat. Many thanks.
I can see how this works now. Appreciate your help.
