as the Title says I have one of the Home assistant gauges that goes out past the decimal point alot further than I want how do I get it to round to one decibel from the decimal like the other 2 without having to use custom guages thanks
Maybe by creating State-based Template Sensor and using it for your gauge?
template:
- sensor:
- name: "Shower Temperature"
unit_of_measurement: "°F"
state: >-
{{ '%.1f' | format(states('sensor.shower_temperature') | float ) }}
Replace sensor.shower_temperature
with your entity_id
for Shower Temperature.
Okay thanks was hoping for a more direct but I can do this as well thank you
okay this is working except for it only showing whole numbers what do I need to change get it to show one digit readings past the decimal for example 105.8 instead of it rounding up to 106.0 ?
sensors:
main_shower_temp:
value_template:
{{ '%.1f' | format(states('sensor.u_by_moen_00651a_current_temperature') | float ) }}
friendly_name: "Main Shower Temperature"
