Is there a way to get a timestamp for tracked devices?
Example:
Device1 away since 08.00 a.m
Device2 at home since 7.00 p.a.
Example:
why not make a mqtt device tracker and update this state using node red?
do you have an example for this case?
You can access the last_changed
on most things this way:
{{states.device_tracker.xxx.last_changed}}
I tested this in the developer/template panel. You can then add some more formatting around it to put in the format you want. For example:
Xxx has been {{states('device_tracker.xxx')}} since {{states.device_tracker.xxx.last_changed.strftime("%b %d, %Y at %I:%m %p")}}
results in:
Xxx has been home since Jan 11, 2021 at 08:01 PM
I included the date because, well, during these times we find we don’t leave the house all that often…
If you want to have these be a virtual sensor state, then you can create a sensor template with this as the value. Then you can add the sensor to your front end.
EDIT: Just realized the last changed is in UTC time, which probably isn’t what you are looking for. Change that portion to:
{{as_timestamp(states.device_tracker.xxx.last_changed) | timestamp_custom("%b %d, %Y at %I:%m %p")}}
as_timestamp
puts converts the timestamp to local time.
For completeness, the sensor will be:
sensors:
tracker_xxx_last_changed: <--- name this how you want it
value_template: >
KP115-2 has been {{states('device_tracker.xxx')}} since {{as_timestamp(states.device_tracker.xxx.last_changed) | timestamp_custom("%b %d, %Y at %I:%m %p")}}
The sensor state then looks like the output listed above
wow, I used in sensor.yaml:
sensors:
tracker_maxi_last_changed:
value_template: >
maxi has been {{states('device_tracker.maxi')}} since {{as_timestamp(states.device_tracker.maxi.last_changed) | timestamp_custom("%b %d, %Y at %I:%m %p")}}
but I got
Invalid config for [sensor.template]: expected dictionary for dictionary value @ data['sensors']. Got None
extra keys not allowed @ data['tracker_maxi_last_changed']. Got OrderedDict([('value_template', 'maxi has been {{states(\'device_tracker.maxi\')}} since {{as_timestamp(states.device_tracker.maxi.last_changed) | timestamp_custom("%b %d, %Y at %I:%m %p")}}\n')]). (See ?, line ?).
Your yaml syntax is wrong. You have given space in front of sensors in the second line. Try without that like this.
sensors:
value_template: >
Yep - yaml is ultra sensitive to spacing. The standard indent is 2 spaces.
Looks the line starting with value_template needs to move to the right one more space.
@nuki47 - copy what I listed exactly and change the names to yours being careful to not change the spacing. Yaml spacing is unforgiving. I have this working on my system.
