I’m struggling with the following:
I have an automation that effectively ‘routes’ a notification to the correct recipients (more specifically, it catches notifications sent to a dummy service, decides who you should receive it and then then sends out a copy to each recipient). This has worked fine for notifications originating from Alarmo.
However, for notifications originating from the Alert-integration, I’m receiving the error “Error rendering data template: Result is not a Dictionary” for the step:
I can’t make sense of this error though, because the trigger-variable (as shown in the automation trace) for both is essentially the same. (Using diffchecker on both: Example with a notification originating from Alarmo:
idx: '0'
alias: Melding naar 'automatisering'
platform: event
event:
event_type: call_service
domain: notify
service: automatisering
service_data:
title: Schakel het alarm uit
message: alarmactivatie binnen 30 seconden
doel: verantwoordelijke personen nu thuis
priority: high
ttl: 0
channel: beveiliging
tag: alarmo
actions:
- action: ALARMO_DISARM
title: Uitschakelen
origin: LOCAL
time_fired: '2024-08-14T19:36:58.958928+00:00'
context:
parent_id: null
user_id: null
description: event 'call_service'
Example with a notification originating from Alert:
idx: '0'
platform: event
event:
domain: notify
service_data:
message: is nog open
title: achterdeur
priority: high
ttl: 0
tag: achterdeur
origin: LOCAL
time_fired: '2024-08-15T14:12:30.138788+00:00'
context:
parent_id: null
user_id: null
I have other Alarmo-notifications (that also work without issue) without “actions: …” so that (by itself) isn’t it.
So, if “{{ trigger.event.data.service_data }}” in the second case is not a dictionary, what is it and/or how could I make it one?
Normally, I’d use the template developer tool to figure out similar type issues; but here since it’s in the trigger variable of an automation/the data of an event, I can’t immediately see how I could do that.
Well yes, obviously. Not sure how I could have gotten the above output if I was trying to use an alert as such as an automation though?
It probably got lost in the noise, but my original goal is to achieve what a “dynamic notify group” (which doesn’t exist, afaik) would do. To do so, I have both Alarmo and Alert send their notifications to a dummy notify service, configured as (so without any actual services associated):
notify:
- platform: group
services:
Then the automation mentioned in the original post has as trigger a notification being sent to this dummy notify:
Up to there, everything works as expected (or at least, I experience no issue with it).
The issue comes when I try to use {{ trigger.event.data.service_data }}, as this gives the error “Error rendering data template: Result is not a Dictionary” when the source of the trigger is a notification originating from Alert (but the same does not happen with one originating from Alarmo), while I see to functional difference in the trigger object of both (see above).
I’ve actually made some progress: turns out that–for the notification originating from Alert–the nested ‘data’ (as appears under trigger.event.data.service_data.data) is not a regular dict but an OrderedDict.
Uitgevoerd op: 17 augustus 2024 om 13:01:13
Fout: expected dict for dictionary value @ data['data']
Resultaat:
params:
domain: notify
service: an
service_data:
title: achterdeur
data: >-
OrderedDict({'doel': 'verantwoordelijke personen nu thuis', 'priority':
'high', 'ttl': 0, 'channel': 'beveiliging', 'tag': 'achterdeur'})
target: {}
running_script: false
It seems the OrderedDict can be turned into a regular dict by using in the above split-version:
, so I don’t have to e.g. check if {{ trigger.event.data.service_data.title }} even exist.
({{ dict(trigger.event.data.service_data) } leaves the nested OrderedDict, so that isn’t the solution.)
