RPC Shutdown wont work with Windows hello
I am using RPC Shutdown, but it won’t work. My PC uses my Microsoft Account with a windows’ hello pin. If I am using the pin as password, it won’t work.
- address: 192.168.xxx.182
  alias: NMPC
  credentials: nxxx%6xxx
  delay: 0
  message: >-
    Home Assistant is shutting down this PC. This cannot be canceled. Please
    save your work!
Log:
[09:48:18] INFO: Shutdown NMPC -> 192.168.xxx.182
Could not connect to server 192.168.xxx.182
The username or password was not correct.
Connection failed: NT_STATUS_LOGON_FAILURE
[09:48:22] ERROR: Shutdown failed:
You should be able to make a local user account for the RPC call.
Rightclick your start button and choose computer administration.
The pin is NOT a password - it’s a pin. It’s the something you know part of a multi factor login. Its combines with something you are and or something you have to provide login to hello which unlocks the box.
You must use the PASSWORD for an RPC call. You can get / reset your password in your ms account.
If your account is now passwordless you will have to create an application password for your account to make it work.
Wally if it’s win home - the local admin (and possibly the Owner account) was disabled when the user used a windows hello account t and it will stay that way unless they edit local security policy
Never worked much with windows Home, so I believe you.
