I’m running home assistant with an external ssd usb disk on a rpi3B+.
I want to save and compare for ex. Electric data over years. Therefore I want to put everything in influxdb and create visuals with grafana.
Is my configuration capable of running HA, influxdb and grafana all together ?
I also have a rpi2 , is it better to run it on a separate device ?
koying
(Chris B)
2
I run the 3 of them on a rpi4 4 Gb and it’s fine.
Now rpi4 is quite a step up above rpi3b+. I doubt 1Gb ram will suffice. Influxdb tends to be ram hungry.
Hi Chris,
I have a rpi3B+ with 2gb ram.
Otherwise I will buy a rpi4 with 4gb ram ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
koying
(Chris B)
4
Yeah, probably a safer bet to buy a rpi4 than spend hours building before possibly coming to the conclusion that it was in vain.
