RPI 4-B failed to start network manager wait online
Installing the Home Assistant OS as recommended on a Raspberry PI 4B with the correct power supply and plugged into a wire to my Ethernet gives the error:
And when the splash screen comes up, the IPv4 addresses for eth0 are blank.
I did a Raspbian install, set up Docker, and put the Home Assistant in the Docker container and that worked.
BUT the Z-Wave JS custom installation fails. The instructions for that are apparently garbage.
So I’m trying to go back to the HA-OS install.
Why can’t it see my network?
Edit: I tried both the 32-bit and 64-bit OS, via Balena as well as the Rasberry PI installer.
It seems to work now; I forced a few things in nmcli, and I think the enabling wifi did the trick (yeah yeah, terrible connection method, not recommended)
I’m a bloody starter on Smart Assistant as well as with raspberry PI but facing exactly the same issue then you. What exactly did you changed where?
I am facing exactly the same problem. I wonder if and how did you solve this problem?
Thanks. You are helping a lot of people as such a problem keeps popping up.
