Looking for a bit of assistance, I recently upgraded my HA to SSD. Running on a RPI 4.
Since updating to the SSD and a new aluminium enclosure my mi Bluetooth temp and humidity sensors are struggling.
Prior I had 4 sensors that would stay connected around the house.
Now I only see the one in the same room as the pi.
I have purchased an extension cable and external BT module. I believe I have disabled the onboard BT in the config but I am not sure.
Is there a way to check in HA which is being used int or ext.
Seems that the ssd Bluetooth range seems a problem that occurs, has anyone got around this
Help appreciated
